Defi, Advance ZD Club Sport Package (RPM signal)
Hi guys, I'm totally out of ideas at the moment and really need some help
I bought the Defi Advance ZD for my 2005 350Z.
I've wired everything up but the tachno doesn't seem to be working, as i had followed the instruction but i "think" our ECU and the one in japan are different.
Then i had tried pinning the signal from the back of the ECU from injectors and ignition (pin 62) as well as some guys had mention on the forum but still no luck. Some has mentioned that the ignition pin on the back of the ECU might be too weak, so I had bought the MSD, Tach Signal GMR Pickup (http://www.msdignition.com/product.aspx?id=4721), after wiring it all up... it still didn't work...
0 RPM
On page 66 of the instruction (http://www.defi-shop.com/media/zd.pdf)
It says Waveform, V1: 4V and above, V2: 1V and below.
Would this be related? What else can i do trying to resolve this issue that I'm having?
Anyone else had installed the advance ZD on the 350z?
Thanks.
Thanks.
