5AT to 6MT swap almost done...
Old Feb 4, 2012 | 01:52 PM
driftk1d's Avatar
driftk1d
Default 5AT to 6MT swap almost done...
But I'm having some problems...the car will crank but won't turn over. It's getting fuel but no spark. What could be wrong?
I've been using this guide
http://m.g35driver.com/forums/showth...=345132&page=5
At the bottom it says I don't need the ecu or harness and I hooked up a 12v wire to plug 53 on the IDPM..is there anything else I missed?
Old Feb 4, 2012 | 02:35 PM
abushong504's Avatar
abushong504
Did you change the BCM or ECU? I didn't read through the DIY? I know that if the security mode is activated it won't let spark to occur. You can tell if this is on, if the alarm indicator light is constantly blinking I think. I am trying to remember.
If this is the case, you made need to get your keys mated up with the ECU or BCM. Only a Nissan Tech can do this.
Old Feb 4, 2012 | 03:22 PM
sdZ33's Avatar
sdZ33
Hit up Ryder32 on here... I remember him telling me something about the bcm giving him a problem, but he resolved it and successfully completed the swap...
Old Feb 4, 2012 | 09:43 PM
driftk1d's Avatar
driftk1d
I did not. The red light flashes until I put the key in then it goes away though. It usually goes away after I unlock it but it didn't...
Old Feb 5, 2012 | 10:23 AM
driftk1d's Avatar
driftk1d
Bump.
Old Apr 11, 2012 | 05:41 AM
silvertouringz's Avatar
silvertouringz
did u manage to start ur car?
Old Apr 11, 2012 | 07:58 AM
driftk1d's Avatar
driftk1d
yeah, i managed to put the flywheel on wrong. After i fixed it it started right up! This swap is nearly identical to swapping the transmission on a 240.
chief3630
Feb 29, 2016 02:54 PM
SpartanZ32
Oct 22, 2015 09:36 AM
Stevo Z
Oct 3, 2015 09:14 PM
SharX59
Sep 27, 2015 09:23 AM
