Welded diff with traction control?
Old Feb 19, 2012 | 01:41 PM
kenny9596's Avatar
kenny9596
Default Welded diff with traction control?
Ok guys i have a quick question i did some looking with no answers. Any way im thinking of welding my diff to drift but my car is a daily driven car so i was wondering if i would still retain/use my traction control or not and just go ahead and delete it.
Old Feb 19, 2012 | 04:11 PM
bbs350z's Avatar
bbs350z
just buy a proper lsd. these cars arent 240's yet lol.
Old Feb 19, 2012 | 05:18 PM
jerryd87's Avatar
jerryd87
horrible idea for a street car, unless you want the tires to chirp around every corner and wear horribly when trying to daily drive. expect to replace tires much more frequently if you do this(that not even counting the drifting).
Old Feb 19, 2012 | 05:39 PM
albinobob's Avatar
albinobob
Been rocking the welded diff since '09 and love it. You're going to want to get rid of the traction control and ABS/EBS for drifting anyways. I have a base model so I can't comment on how it'll react to the welded diff.
FYI: I daily my car and replace the back tires every month or two. But most of that wear is from drift monthly drift events.
Old Feb 19, 2012 | 05:44 PM
jerryd87's Avatar
jerryd87
its not really quicker wear that kills them with a welded diff street driving its the abnormal wear, you get high and low spots where the tires skip going around corners because the two wheels need to spin at different speeds for street driving. welded diff dosnt allow that, whole reason limited slip diff exists, even without the drifting the tires wouldnt last much longer then 3 or 4 months before you had horrible road noise like your running over the highway "wake up" strips from the abnormal wear, which is really bad on the suspension since its actually causing the wheels to bounce on smooth pavement slightly once the tires wear like that. thats why i couldnt run my 84 camaro on the street, it had a full spool in it(pretty much does the same thing as a welded diff without compromising strength from welding anything.)
Old Feb 19, 2012 | 06:10 PM
Italianjoe1's Avatar
Italianjoe1
TCS won't know the difference, it looks for different wheel speed which will not change with the diff welded.
Old Feb 19, 2012 | 07:52 PM
AngelsVQ's Avatar
AngelsVQ
i hate this reply. and yes they are
Old Feb 20, 2012 | 06:43 PM
bbs350z's Avatar
bbs350z
keepin it real...and keeping the streets safe
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
