rev-up motor on non-rev harness and ecu?
Old Mar 21, 2013 | 08:44 PM
Carter86's Avatar
Carter86
Default rev-up motor on non-rev harness and ecu?
Searched and found some threads on other forums but not on my350z.com
I have 04.5 350z and my motor is about to die. I currently have 140k miles and the oil pump is dying and I have rod knock and lifter ticks.
I found a good motor for very good price but it is off from 05 G35 6 MT. The seller confirmed me that it is a rev-up motor.
I want to know if it would bolt up on my non-rev up harness and ECU without any problems. I do understand that rev-up motor has exhaust cam control and etc. Will I be able to run the car for Daily driving? Also, is haltech my only option if I want to tune the car?
Old Mar 22, 2013 | 08:46 AM
silva92's Avatar
silva92
Same issue im going with right now. Give me the weeke and ill have an answer for you. Ive heard yes ur fine and I've heard it wont idle. As well as it wont bolt up to my auto. So ill get back to you this weekend or monday.
Old Mar 22, 2013 | 12:26 PM
Carter86's Avatar
Carter86
I've had a pm from a forum Member who told me that I gotta swap the cams from the de motor to rev up and timing covers. I don't have to run the rev up harness or the ecu
I gotta get the cam plug ins from injected performance which is $27.
I'm gonna check out the rev up motor on Monday and see if it is in good condition
Old Mar 22, 2013 | 12:31 PM
str8dum1's Avatar
str8dum1
u dont have to swap cams. you just need the exhaust cam plugs like you mentioned.
Old Mar 22, 2013 | 06:55 PM
meatbag's Avatar
meatbag
Youll want to switch the cams. The cams have different specs.
Old Mar 23, 2013 | 01:03 AM
mw9's Avatar
mw9
in for updates
Old Mar 23, 2013 | 02:20 AM
bmyles's Avatar
bmyles
But if he gets an UpRev tune, it will be fine, I would imagine. Car might run a little funny on stock tune, but I don't think they're different enough for it to go haywire?
Old Mar 23, 2013 | 06:38 AM
Carter86's Avatar
Carter86
I'm doing test pipes and headers at the same time and get an uprev tune asap. I have angled spacer from motordyne, drop in filter and megan exhaust. So let's see how things go. Does uprev reflash turn off cel from test pipes?
Old Mar 23, 2013 | 08:08 AM
Calinismo350z's Avatar
Calinismo350z
nop, you need to get the extension on the o2 sensor.
Old Mar 24, 2013 | 08:01 PM
meatbag's Avatar
meatbag
The cam center lines are different.
Old Mar 26, 2013 | 10:24 AM
Carter86's Avatar
Carter86
Ok I took a look at one motor last night and it wasn't too good of a condition. I'm going to look at another one. Its another rev up motor
Old Mar 28, 2013 | 03:49 AM
Carter86's Avatar
Carter86
I tried the celfix before and it didnt work for me. So I guess the idea of getting the test pipe is gone now
I called the injected performance and sadly, they dont have the plugins in stock anymore.
http://www.injectedperformance.com/i...for350zg35.htm
After a quick chat with the owner, he advised me to use the stock ones. I cant really picture what I am supposed to do without looking at the camshafts in front of me.
I will post the pics when I start the swap.
Here is the picture of the motor I bought last night.
Old Mar 28, 2013 | 10:32 AM
Carter86's Avatar
Carter86
Just got an email from z1 about this question. Uprev osiris can turn off the cel caused by test pipe without any problem.
Old Apr 4, 2013 | 03:01 AM
silva92's Avatar
silva92
I just swapped a rev up motor into my automatic 03. Buy stock cam sensors for the rear st the junk yard.. (theyll stay unplugged) and the front two sensors will also stay unplugged. Cars been runing great for 1000 miles with no check engine lights.
Old Apr 4, 2013 | 12:16 PM
Carter86's Avatar
Carter86
Stock cam sensors?
Old Apr 4, 2013 | 12:23 PM
omgitsweasel's Avatar
omgitsweasel
Not much to add specifically, but just make sure that if you have any exposed harness side connectors that you cover them up to prevent moisture shorting anything out.
Old Apr 9, 2013 | 08:39 AM
Carter86's Avatar
Carter86
Swap is done. I had to take the tranny out twice because I installed the flywheel wrong. Vqs have some sensor and if is not installed right, it won't start.
I would have to re learn the idle. Other than that, it runs great. My old motor had bad rear main seal, leaky valve gasket and bad oil pump. Rev up motor on non rev up harness worked for me
Old Dec 3, 2013 | 04:30 PM
theZride03's Avatar
theZride03
bump
Old Dec 3, 2013 | 04:35 PM
theZride03's Avatar
theZride03
im trying this on my 03 m/t and it runs super lean on the 03 ecu and harness
Old May 18, 2017 | 02:28 PM
Sydanette's Avatar
Sydanette
Default swap
are you running it auto or manual setup
