Disk flaw...Still usable?
Old Jul 1, 2013 | 11:14 AM
TopgunZ's Avatar
TopgunZ
Default Disk flaw...Still usable?
There is a JWT clutch and FW for sale but the disk has taken what looks like a drop or a hit from something and now has a defect.
Is this still usable?
Old Jul 1, 2013 | 01:10 PM
dcains's Avatar
dcains
As long as the disk is still flat and true, I wouldn't give it a second thought - maybe clean that edge up with a file and use it.
Old Jul 1, 2013 | 01:42 PM
TopgunZ's Avatar
TopgunZ
Have you seen the cracked out portion by the rivet behind the frayed edge? That is almost what worries me more. The other side is flawless however.
Old Jul 1, 2013 | 01:47 PM
dcains's Avatar
dcains
Can't really see that detail in the pic, and thought it was only the frayed edge that was a concern. If the rivet is cracked, and there's a possibility of the friction material separating from the backing plate, that's a whole different matter, and I would probably not use that disk. Lots of labor to install that part, as compared to the low cost for a new, undamaged part.
Old Jul 1, 2013 | 02:16 PM
TopgunZ's Avatar
TopgunZ
True. I ended up sending this pic to JWT and they had an engineer look at it. He was able to see the crack since he got the full file and said he didnt recommend using it. Not worth the what if, if it turned out bad.
Thanks for the feedback.
Old Jul 1, 2013 | 04:46 PM
dcains's Avatar
dcains
Good job doing your homework and saving yourself some future problems.
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
