'Merica! Go big or go home = installing LS engine into drift car
Old Jul 8, 2013 | 12:24 PM
Mr_White's Avatar
Mr_White
Default 'Merica! Go big or go home = installing LS engine into drift car
Not the first to do this, but it doesn't hurt with more info for anyone who is looking to do this in the future. This build thread will document the steps of upgrading an LS2 engine with L92 heads, then dropping the engine into a 350Z.
To the build:
Fueled Racing is a company that manufactures custom LS swap kits for various vehicle applications. These include everything needed to drop a LS into a vehicle, P/S lines, engine and gearbox mounts, headers that will fit, clutch lines that fit right onto the OEM lines. There are gearbox mounts and main shafts to choose from whether using T56 transmission, a Magnum, GeForce, Jerico and most other popular gearboxes, outgoing spline count and necessary main shaft length all accounted for.
We started to remove the old powerplant. The frame needs some small repair after a little love tap with the outer rail of Wall Speedway New Jersey. So it's time to take care of that too while prepping the LS motor. Also a lot of the hoses you see can be removed now from the elaborate installation of a watercooled turbo setup, hopefully making the engine bay a very clean and simple story in the next few days.
First photo is one of the Fueled Racing engine mounts, ready to bolt on and this will set the engine lower and farther back in the vehicle than other kits, to ensure best weight distribution and low COG. Very solid piece, and designed so that IF the polyurethane piece should breaks in an accident, the bolt will still retain the engine where it belongs, instead of dropping somewhere onto the bottom crossmember and steering rack or damaging a lot of other things in the engine compartment. The mounts are marked up nicely so that the customer doesn't have to waste time on figuring out which side and way it goes in.
A custom Moroso oil pan (with a huge amount of baffles) is supplied with the kit, well proven to avoid oil starvation problems during road race like conditions. The oil pan will fit so that zero mods are needed to the existing vehicle's frame / subframe.
As for the headers, they are very nice and long 4-1 pieces and can be had with thermal coating, or polished. I went for the best thermal management which are a nice mean satin black finished. Pretty impressive headers in my humble opinion. They exit far back and spread wide from the gearbox (making sure to no heat the gearbox oil more than necessary) and it's child's play to attach a couple of 3" pipes to exit at the back of the car (sidepipes not allowed in FD). X-pipe will be something we will try later to see if we can engineer a unique sound character from the engine.
For the motor, it is a GTO 6.0 LS2, low mileage at that, so it looks extremely clean inside out, literally super super clean. The 243 heads were the first to come off though and a pair of L92 heads pre-assembled w springs for .600 cam lift will go on as soon as we have put a CompCams XR281HR off-the-shelf cam into the engine (it is easier to install the cam with the heads off and since they are already off, we can do the cam first).
I'm pretty sure we'll be going with some other cam options in the future but right now time is short ahead of the next event and we need something that will fire up easily work right away without headache such as risking the valves to hit the postins etc. However, with a decent torque curve and increasing hp potential through the rpm range this cam should give pretty awesome performance already.
A lot of the engine planning has been done by research on the LS1tech.com forum, so filtering all the info available I am hoping we're making some good calls based on what's been written about there.
Once thing I haven't seen too much of on that forum is E85. We ran E85 before with great results, and the plan is to do the same here. Injectors from FiveoMotorsport will handle the needed flow up to 800 hp (for future turbo boost on this engine). The car is setup with a fuel cell and my biggest concern is capacity/consumption. The pump is good enough to drain Lake Michigan in an afternoon, but the fuel cell is a lot smaller than that. Remains to be seen how thirsty this engine will be when we are done with it...
Next update in a few days.
Old Jul 8, 2013 | 01:47 PM
graffkid732's Avatar
graffkid732
Nice. Good luck with it
Old Jul 8, 2013 | 05:19 PM
Neeko94's Avatar
Neeko94
How long is the expected turn around time?
Old Jul 8, 2013 | 05:31 PM
terrasmak's Avatar
Looking forward to seeing the updates. BTW you still haven't mentioned what you did to the subframe a month ago!
Old Jul 8, 2013 | 05:48 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Subbed. Kept my Z so I can do this as well. Was going to swap platforms. Post az much as you can on fueled kit. Seems everyone goes sikky
Old Jul 8, 2013 | 06:03 PM
Ruthless18x's Avatar
Ruthless18x
In for updates.
Old Jul 8, 2013 | 06:10 PM
Triji's Avatar
Triji
In just to stare at Ruthless18x's avatar.... Damn that girl is cute!
Old Jul 8, 2013 | 06:44 PM
Mr_White's Avatar
Mr_White
Target is to test this Sunday! But little pieces for missing accessories will be the major pain to set us back 4-7 days. Have to solve that, the rest is cake.
Old Jul 8, 2013 | 06:53 PM
Mr_White's Avatar
Mr_White
The head update is needed for power but also add a new set of parts, rockers are backordered. Bolts for idler pulley dont sell separate, ps pulley comes in twotypes w no good docu except vin which i dont have, fuel rails are different etc. But tmrw we assemble engine w new cam and heads. Clutch is good to go bar flywheel and pp bolts. All that little stuff takes it's share of time. Keep fingers crossed that all stuff gets delivered. One missed delivery if delivery guy takes a part back bc no one to sign for it and we are going to have a tough time making Sunday. Keep fingers crossed.
Old Jul 8, 2013 | 06:54 PM
Mr_White's Avatar
Mr_White
Subframe mod is a trade secret. Just better, faster.
Old Jul 8, 2013 | 07:06 PM
Mr_White's Avatar
Mr_White
Fueled Racing is huge on support. Also engine mounts lower from what I have been able to research
Other than that can kill illusion that it is cheaper than VQ. A VQ gearbox will cost 500, a T56 which is at least as crappy runs 1500 and up. VQ motors cost 1000 for a good one and makes 300 hp. A truck motor costs that and makes less power w more weight. But if you look at BIG BIG power, over 500rwhp, they start to equalize.
Old Jul 9, 2013 | 04:14 AM
djamps's Avatar
djamps
A running VQ is only $1000??? 'working' junkyard VQ's are $2500 and (usually) higher in my experience. CD009 gearboxes are usually more than $500, but under $1500. Although a CD009 (far from crappy IMO) is going to hold way more power than any stock GM gearbox.
Old Jul 9, 2013 | 04:20 AM
QTB's Avatar
QTB
Sub! I've been thinking about switching to the Fueled Racing kit to push my engine back. I can't wait to see some pics of the fitment.
Old Jul 9, 2013 | 05:17 AM
TuckerE36's Avatar
TuckerE36
Mr. White
You said you've gotten a lot of information from Ls1tech forums. There is a member on that forum that does an excellent job tuning cammed LS engines, he's kinda a mini celeb on that forum lol. He's name is Patrick Guerra or by his forum nick name, Pat G. I'd definitely email him if you have any questions.
Old Jul 9, 2013 | 05:40 AM
Mr_White's Avatar
Mr_White
Sorry to hear that, maybe for a HR engine. But here's a chance to make 1500, bc my VQ35DE motor in excellent cond is now up for sale for around 1k, with 6speed. And yes the Z gearboxes have proven to be tough little boxes. The syncros don't last long though so vs a GForce or similar they are not up for the same kind of competition use, over time they will require slower shifting to get in gear. Sorry if I stepped on anyone's toe calling a weakness on the Z gearbox. The point is a T56 isn't looking to be a whole lot better bc similar issues w syncros during track duty.
Old Jul 9, 2013 | 05:42 AM
Mr_White's Avatar
Mr_White
Originally Posted by TuckerE36
Mr. White
Seen the name, good reminder!
Old Jul 9, 2013 | 05:54 AM
Mr_White's Avatar
Mr_White
K hang on for a few days and we'll be able to confirm how big the difference is.
Old Jul 9, 2013 | 06:01 AM
TuckerE36's Avatar
TuckerE36
Yeah just shoot him an email or pm, he's been on that thread and tuning for over a decade.
Old Jul 9, 2013 | 09:01 AM
QTB's Avatar
QTB
FWIW I got a custom cam from Flow Tech Induction (Ed Curtis) and I couldn't be more happy. I made over 450 rwhp with L92 heads and a cam with 10.0:1 SCR, which as I'm sure you know is lower than OEM.
Old Jul 9, 2013 | 09:19 AM
DCJodon's Avatar
DCJodon
Love seeing LS builds. Are the fueled racing kits better/more complete than the Sikky LS kits?
