Any Code experts?
Old Feb 6, 2004 | 12:41 PM
350zdanny's Avatar
350zdanny
I just printed mine out, all 3142 pages of it. I figured I'd use it in the garage, but I just take my laptop down there too.
Old Feb 6, 2004 | 01:01 PM
ecoli's Avatar
ecoli
An error like this is only going to be thrown from idle/part throttle driving. It is thrown when you are outside of the range that the ECU can compensate using the stock O2 sensor under idle & cruise conditions. It isn't monitored at full throttle, so it is possible to have too rich of a fuel trim at part throttle and get this error, but be lean at WOT.
Old Feb 6, 2004 | 01:03 PM
12SecZ's Avatar
12SecZ
exactly, that is why I am off WOT for now. I have been doing allot of the above conditions you mention to avoid WOT until I lowe rmy boost because we were given week rods.
Old Feb 6, 2004 | 01:10 PM
ecoli's Avatar
ecoli
Do you have a dyno chart online for your beast?
Old Feb 6, 2004 | 01:18 PM
12SecZ's Avatar
12SecZ
Not with this current setup of 10 or 9, I have a 411rwhp and a 363rwhp but it was more boost and less boost, I want to be right in the middle. It is easier said than done it seems. I am a belt away!
I haven't dynoed at 9 lbs yet, I plan on it though, I feel comfortable doing so. I have an issue with Dyno's but I am getting over it slowly, I used to dyno every mod before an incident MY highest N/A Dyno is 247, and I did a 346 on N20 slightly fat. I keep them all in a folder.
Old Feb 6, 2004 | 01:25 PM
12SecZ's Avatar
12SecZ
This was in 2002!
http://home.surewest.net/mailmax/dynostock.jpg
Time flies huh?
No body kit, no rims, and just a CAI.
Look at my cute little zip tie on grill
Old Feb 9, 2004 | 12:33 PM
g356gear's Avatar
g356gear
Hey Guys I have a strange code for you.
4 fast blinks, 2 fast blinks, 10 fast blinks.
This makes no sense on the site listed earlier in the thread. Any ideas?? And yes the 10 blinks are followed by the 10 slower blinks said to follow the code flash sequence. Thanks.
Originally posted by 12SecZ
Awesome, better rich than lean!
Big sigh of relief.
Turn the engine to run where the dash lights come on.
Count 3 seconds (you need a watch it is exact.)
after 3 seconds press the accelarator to the floor then release 5 times in 5 seconds
wait 7 seconds
push and fold the acclerator to the floor for 10 seconds until the CEL starts flashing.
It will then blink 10 times (trust me w/o a watch it won't work)
Count the blinks, after 10 count the series of 3.
So in my case it goes like this
3 seconds on
5 seconds push, repeat push
7 seconds wait
10 seconds push hold
10 blinks pause
1 blink
7 blinks
5 blinks
then the blink cycle loops again starting at ten
To clear press and hols the accelerator for a full 10 seconds then release
then turn key off then restart, CEL is gone
Peas!
I use the Nissan programming built in found on ther CD there are all kinds os thricks in there like resettting the MAF andf TB PS etc
Old Feb 9, 2004 | 12:50 PM
zzzya's Avatar
zzzya
I believe a 10 represents a 0
P0420 = Catalyst Efficiency Below Threshold (Bank 1)
Old Feb 9, 2004 | 02:29 PM
g356gear's Avatar
g356gear
My test pipes would probably explain that code then. Thanks for the help.
Old Feb 9, 2004 | 02:41 PM
350zdanny's Avatar
350zdanny
How long have you had your test pipes? My O2 sensors got caked up in no time. Maybe you should check out yours.
dan
Old Feb 9, 2004 | 04:16 PM
12SecZ's Avatar
12SecZ
Yeah our 02's are the wink link in this upgrade chain they are cheap.
On LS1's we could add new/better 02's is this an option on the the Z?
Old Feb 9, 2004 | 05:11 PM
chazzg's Avatar
chazzg
Well i got in my Z tonight to go to work and it would not start. It started to turnover but after about 2 seconds it just Clicked. It sounds like my Starter. I Got code 615 from the self test But it would not reset. 615 is Starter Relay. i was wondering if anybody with the Tech Manual ( I have one I just can't find it ) would see if there is an easy Fix. I really Don't want to tow my Car to the Dealership, if i can do something My Self. BTW has anybody else hear of this Yet?
Old Feb 9, 2004 | 07:27 PM
12SecZ's Avatar
12SecZ
Isn't that one of the TSB's where a relay falls and it dies and/or fails to start? I hope so bro if not cheap fix but still should be a free fix!
Old Feb 9, 2004 | 08:32 PM
daking350's Avatar
daking350
Ithink that was the Crank
position Sensor..The car would just shut off on people while they were driving!! There is a recal on that but only 140-160 cars I think...
Old Feb 9, 2004 | 08:42 PM
daking350's Avatar
daking350
ChaZZ..The STARTER RELAY should be in the relay box right in front of the Battery...It should be labeled..Check all your relays and fuses..Dont forget to check the fuses in the battery compartment under the winshield wiper cowl..Those are all the major fuses hiddne in there..
etkms
Jun 19, 2022 06:30 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
carid
Misc.
Sep 10, 2015 06:16 AM
