Cruise control
Old Mar 20, 2015 | 08:10 AM
Gtsingh91's Avatar
Gtsingh91
Default Cruise control
I've been searching on this issue for 2 months since I bought by car but since the weather is finally warming up, Im able to get outside. My cruise control button on my 07 HR 6-speed isn't turning on at all. Press the button on the steering wheel at all different speeds and it's not even turning on. My first guess is the fuse, but where is it? I found a 2008 owner's manual (can't find mine) and I see the location of the fuse boxes (one near the clutch pedal and one near the battery under the hood) but I can't find the Cruise control fuse. Any insight would be greatly appreciated.
Old Mar 20, 2015 | 03:33 PM
KornerCarver's Avatar
KornerCarver
Does your horn work? If not, you might have a broken clock spring.
Old Mar 22, 2015 | 06:44 AM
Gtsingh91's Avatar
Gtsingh91
Horn works and so does the Bluetooth controls and music control, it's just the cruise control not doing anything at all whether you press the cruise on/off or the set button. No lights come on.
Old Mar 25, 2015 | 10:52 AM
str8dum1's Avatar
str8dum1
there is no fuse. check the brake and clutch switches under the dash to make sure they are disengaging
Old Mar 27, 2015 | 07:06 AM
Gtsingh91's Avatar
Gtsingh91
Okay, I'll check that. But even if those switches were bad, wouldn't the cruise light at least turn on and not let me set it? Nothing is coming on at all when the cruise on button is pressed.
Old Mar 28, 2015 | 05:24 AM
KornerCarver
You might consider taking it to a dealer to get the cruise control repaired.
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
