Clutch Problems 04 350z
Old Mar 23, 2015 | 10:41 PM
NTrunz22's Avatar
NTrunz22
Default Clutch Problems 04 350z
Need help with a clutch problem The car has about 60,000 Miles on it when I go to put it in first gear the shifter like stops an doesn't go in to gear I have to let off the clutch like half way an then it goes into gear it does the same thing some times when I throw it into reverse. Any suggestions on what this is?
Old Mar 24, 2015 | 02:37 AM
oldschool350z's Avatar
oldschool350z
Good to see someone else in Buffalo.
If you're trying to put it in first when not stopped it's a safety feature so you dont downshift and do damage. For the reverse issue could be you're not pushing down first then going to reverse hard enough.
Old Mar 24, 2015 | 05:47 PM
NTrunz22's Avatar
NTrunz22
Yeah tht could be the problem also I changed the tranny fluid with redline but it gets Alittle notchy when it starts to get colder out but she's garaged so thanks for the input bro an maybe it's cause the car doesn't wanna be driving on the shitty roads in Buffalo also haha
