Found my clutch problem, now to buy parts
Old Nov 20, 2015 | 11:08 PM
terrasmak's Avatar
Sheared my flywheel bolts at the track. Flywheel has been on the car for 118k miles, it's trash now. Flywheel was not removed when I did my clutch 500 miles ago . Tomorrow I try to clean up the crank , hopefully it's still good
Pulled the trans back when dropping it and started to see the webbing on the back of my block, was sitting there like" this isn't good"
Now to figure out what ARP bolts I need to buy. Going to grap the flywheel and pressure plate bolts
Attached Thumbnails Found my clutch problem, now to buy parts-image.jpeg   Found my clutch problem, now to buy parts-image.jpeg   Found my clutch problem, now to buy parts-image.jpeg
Old Nov 21, 2015 | 01:42 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you're being pretty optimistic about this....
whats the plan? Try to get the threads to back out with an extractor?
Old Nov 21, 2015 | 05:40 AM
guitman32's Avatar
guitman32
Pretty hardcore. Hope the crank isnt damaged, good luck.
Old Nov 21, 2015 | 06:19 AM
HRMoneyPit's Avatar
HRMoneyPit
Yeah that looks really bad
Old Nov 21, 2015 | 08:40 AM
jv350z's Avatar
jv350z
ouch. good luck
Old Nov 21, 2015 | 08:49 AM
terrasmak's Avatar
Exactly the plan , fingers crossed
Old Nov 22, 2015 | 09:14 AM
guitman32's Avatar
guitman32
If the flywheel mounting surface is not level, it may be toast...but I think the biggest challenge will be removing the bolts cleanly.
It mustve felt really responsive revving with no flywheel, lol. Good luck!
Old Nov 22, 2015 | 10:18 AM
terrasmak's Avatar
Revved very well without the flywheel, no idea how it kept running or why it didn't pop a CEL instantly. I guess the crank sensor is not that important
Old Nov 22, 2015 | 10:41 AM
i8acobra's Avatar
i8acobra
What?
Old Nov 22, 2015 | 09:13 PM
terrasmak's Avatar
Just snapped my first EZ out , got the bolt to turn 1/2 turn before it snapped.
What to do, what to do.
Old Nov 23, 2015 | 03:20 AM
jhc's Avatar
jhc
General & Tech Moderator
I like Cobra's idea. Meanwhile they should exchange the broken extractor. Kobalt, Craftsman etc all guarantee hand tools for life. Liquid Wrench soaking overnight, then PB Blaster and a propane torch.
Good luck!
Old Nov 23, 2015 | 05:43 AM
rancor's Avatar
rancor
You could also try to use a center punch to spin the bolt out after soaking in penetrating oil.
Old Nov 23, 2015 | 07:41 AM
terrasmak's Avatar
Thinking center punch to punch the broken EZ out all the way thru. I completely drilled thru the bolt prior, then open it up for a larger sized EZ out.
Also going to take a Roloc disk ( blue or red) to the crank surface to clean the aluminum off it. Seems like the steel crank should be ok under the aluminum that is imbedded into it
Old Nov 30, 2015 | 08:17 PM
terrasmak's Avatar
Down to 2 bolts left in the crank. One has the snapped EZ out, but I may be able to salvage this thing.
Old Nov 30, 2015 | 08:49 PM
HRMoneyPit's Avatar
HRMoneyPit
The other threads still fine?
Old Dec 1, 2015 | 04:37 PM
terrasmak's Avatar
Seem good, but will run a tap past them to make sure they are perfectly clean
Old Dec 1, 2015 | 04:45 PM
travlee's Avatar
travlee
Master
good to hear
Originally Posted by i8acobra
What?
pssssssshhhhhh, come to the dark side with me, could you imagine this in the Z?
Old Dec 1, 2015 | 04:47 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
That vid was fun to watch. I think that's the first time I've seen your car in action.
Does.Not.Sound.Or.Look.Stock
Old Dec 1, 2015 | 04:49 PM
SmoothZ's Avatar
SmoothZ
Except for when your car pooped itself. Heck, I would've shat myself if I heard that happen to my Z while driving it. Makes me want to cry.
Old Dec 1, 2015 | 05:17 PM
HRMoneyPit's Avatar
HRMoneyPit
I'm curious what caused this though?
