Upper oil pan fix?
Old Apr 24, 2016 | 10:17 PM
Siqcology's Avatar
Siqcology
Default Upper oil pan fix?
Recently cracked the part of the oil pressure sensor mount. Small hair line cracked. Used jb weld but sort of half ***'d it. Decided to go with Devcon but which epoxy would be best to help seal the cracks? Thanks in advance.
Dirty.
Cleaned up
Close up
Old Apr 25, 2016 | 08:29 AM
iideadeyeii's Avatar
iideadeyeii
For oil pan's I've used a jb steel stick weld(it's like clay) to seal a 1/4" hole in an oil pan. It never failed
You just need to clean all the oil off. I put a vacuum on the oil fill to make sure no oil would contaminate the hole while I was sealing it
hairpincorners
May 10, 2012 05:26 AM
Mr_Q
Southern California
Jun 7, 2006 10:39 PM
keeptrying
Dec 19, 2005 07:51 PM
cloudy
Jul 27, 2005 11:05 PM
synth19
May 18, 2004 06:00 AM
