Bad valve seals or piston rings
Old May 3, 2016 | 03:52 PM
Karwo Z's Avatar
Karwo Z
Default Bad valve seals or piston rings
I have a 05 rev up with crazy high oil consumption problems 71k miles. Cylinder 4 is where the problem is. The spark plug is badly fouled up on the tip and theres oil on the bottom. On first start up it smokes a lot of white smoke, then it calms down, only smoking when i rev it up, after a few revs the smoke isnt as bad. No loss in power, havent done a compression test yet, what do you guys think, valve seals or piston rings.
Old May 3, 2016 | 04:02 PM
terrasmak's Avatar
You should do a leak down check.
My bet, seals , but could be either.
Old May 3, 2016 | 04:26 PM
Karwo Z's Avatar
Karwo Z
If it is the seals, should i only replace the valve stem seals or other things too while im at it
Old May 3, 2016 | 05:20 PM
0jiggy0's Avatar
0jiggy0
You're looking in the 20 hour range for the seals. At 71k you may want to think about a rebuild/upgrade, do a full compression and leakdown test.
Old May 4, 2016 | 05:50 PM
CK_32's Avatar
CK_32
Compression or leak down test.
Also make sure the p-rings gaps are not aligned. They should all be staggered.
Z33E
May 3, 2016 09:48 PM
junkyardwarrior
May 3, 2016 02:18 PM
Gabriellajergos
May 2, 2016 07:06 PM
bean_vq35de
May 1, 2016 05:50 PM
