Cam bearing cap torque
Old Jun 1, 2016 | 03:38 PM
Turbo_Tay's Avatar
Turbo_Tay
Default Cam bearing cap torque
Hey I am getting close to finishing my built motor/ twin turbo build and have run into a problem. I am putting the motor back together but I cannot fine torque specs for the camshaft bearing caps anywhere. If anyone knows them that would be very helpful to my build. Thank you very much!
Old Jun 1, 2016 | 04:55 PM
Conway_160's Avatar
Conway_160
They get torqued in steps, 10in lbs; 40-55in/lbs; 71-89in lbs.
Something like that ill post exact numbers when i get home.
Old Jun 1, 2016 | 05:32 PM
Turbo_Tay's Avatar
Turbo_Tay
Default Cam bearing caps.
Do you or anyone have any idea what damage could happen if they were over tightened to 30-40ft pounds?
Thanks for the response!
Old Jun 1, 2016 | 06:35 PM
Conway_160's Avatar
Conway_160
yea if you over tighten you can snap them off and then your in for a very very bad day, ask me how I know...
Page 82 of the EM section of the FSM
Old Jun 1, 2016 | 06:39 PM
Turbo_Tay's Avatar
Turbo_Tay
Attachment 378302
I didn't snap them luckily however I did tighten them to the point the motor dosnt start. I'm going to loosen and retighten to spec and hopfully all my problems will be solved. Thanks for all the help.
Owensj
May 23, 2016 05:36 PM
Owensj
May 5, 2016 02:23 PM
