Revup swap help!
Old May 10, 2017 | 11:36 PM
Revswap's Avatar
Revswap
Default Revup swap help!
Hey guys, here's the deal I have a 2004 g35 6mt coupe with de motor pulled out, am gonna pull harness and ecu as well.. I have a revup swap with harness and ecu included my only problem is I didn't get the matching bcm and key , my main question is will the dealership be able to re program the key if the bcm and ecu don't match? Thanks for the helps guys!!
Old May 11, 2017 | 03:07 AM
armt350z's Avatar
armt350z
If all you are worried about is NATS, UPREV can disable that in the new ECU. I'm not sure if Nissan can just reprogram it for a new key, but its stands to reason that they should be able to.
