Help with error p0360
Old Jul 5, 2017 | 11:35 AM
I-Z-U-NV-ME's Avatar
I-Z-U-NV-ME
Default Help with error p0360
I get a misfire in cylinder #6 change coil , work for about a month then started up again , any suggestions would be greatly appreciated
Old Jul 5, 2017 | 03:53 PM
Atreyu'z 350's Avatar
Atreyu'z 350
Where'd you get the coil?
Old Jul 5, 2017 | 04:24 PM
I-Z-U-NV-ME
got it at autozone
Old Jul 5, 2017 | 04:26 PM
I-Z-U-NV-ME
got it at autozone
But I don't think it's the coil cause nissan replaced the number 1 cylinder coil and I swapped it with the autozone one and it still give me a misfire on cylinder 6.
Old Jul 6, 2017 | 05:27 AM
Atreyu'z 350
OK. You mean code P0306. It could be a clogged or failing injector on cylinder #6 as well; or compromised wiring that connects to coil #6, or injector #6. Check the condition of those harnesses and the wiring leading to those harnesses. Also, check for vacuum leaks in the intake system: Throttle body, Intake plenum(Although least likely to throw that code, but possible).
