High RPM Transmission Buzzing Noise (Aftermarket)
Old Jul 6, 2017 | 10:28 AM
Deteria's Avatar
Deteria
Default High RPM Transmission Buzzing Noise (Aftermarket)
I got South Bend Complete Clutch & Flywheel Pack with Quiet disk. Car drives great, but whenever I get my RPM up (6k+) and I let off the gas as I'm about to shift, I get a grindy buzzy noise from my transmission.
Just wanted to see if anyone else has the same issue as I do and wondering if it's normal.
Old Jul 6, 2017 | 05:23 PM
dcains's Avatar
dcains
I'd be looking at the exhaust.
Old Jul 7, 2017 | 05:08 PM
Swaglife81's Avatar
Swaglife81
Sounds like resonance. You could try a good butyl aluminum like dynamat or some other brand of cld tiles under the carpet in that area to stop sound. Or make sure everything is tightened up on exhaust
Old Jul 7, 2017 | 08:45 PM
Deteria's Avatar
Deteria
I'll double check my exhaust when it gets cooler. Just wanted to see if it was my transmission / flywheel.
Old Jun 25, 2018 | 07:50 PM
Josh Vaow's Avatar
Josh Vaow
I also installed south bend stage 3 with lightweight billet flywheel and cmak delete kit, I’ve got over 3k miles on the new parts, and at high rpms I am experiencing a buzzing/ metallic rattling noise thru my clutch pedal itself. Was wondering what conclusion you might have come to.
Old Jun 29, 2025 | 04:22 AM
Roberto Lo Papa's Avatar
Roberto Lo Papa
5 Year Member
Default Was that buzzing sound like this?
https://share.icloud.com/photos/006p...SRb8no4ypqO0dA
what did you end up doing?
