Clutch pedal slow to return
Did you replace any other parts like the master, clutch line, or slave - or are all those components still original?
When I installed my clutch/flywheel, I had to adjust the push rod on the MC and the clevis. I did upgrade the MC. I believe it is recommended to upgrade the MC if you're putting in a stronger clutch, but not always necessary.
Maybe try bleeding it again before throwing more parts at it?
