Mishimoto fan shroud install! Help needed
Old Aug 29, 2017 | 12:46 PM
bobbyz350's Avatar
bobbyz350
Default Mishimoto fan shroud install! Help needed
My new fan shroud is coming in tomorrow so tonight I will be taking my old one out and needed info help on can I remove it from the bottom? I seen removal from the top and I was wondering if there was any way of dodging the top removal? Any help will be appreciated
Old Aug 30, 2017 | 06:04 AM
eZg's Avatar
eZg
I cut my stock shroud to make it easier to remove from the top.
It's been a while so I can't rem why it looked much tougher to remove from the bottom.....maybe position of the lower radiator hose?!?
What is your reason for NOT wanting to remove the shroud from the top??
Old Aug 30, 2017 | 06:35 AM
CK_32's Avatar
CK_32
It's very possible.
Youll probably have to remove the rad hose on the bottom. But there is no way of doing it. Just shove it in and figure out which angle it needs to go in. Not much to it.
Old Sep 4, 2017 | 04:07 PM
bobbyz350's Avatar
bobbyz350
Originally Posted by CK_32
It's very possible.
Agreed it was an easy install lol I pulled mine from the top
