Aftermarket radiator fan hr
My fans aren't spinning at all so I'm looking to replace them, are there any options for 07-08 models. If not is there an upgrade to the oem via getting better motors for the fans or is oem best.
Its actually pretty common, to the point that I think there is a tsb on the HR fans going out. Oreilleys can order new ones, the ones on their site from import direct is actually a VDO fan assembly which is a OEM manufacturer for a lot of brands. It also has a lifetime warranty. Check the fuses aswell though, because mine failed both at the same time.
Ronp350z
Cooling System
Aug 15, 2013 07:04 PM
