SPL Solid Differential Bushing GAP
Old Feb 3, 2018 | 10:24 PM
rottingcat's Avatar
rottingcat
Default SPL Solid Differential Bushing GAP
Just installed SPL Solid Differential bushings and I have a small gap in between the subframe and the differential at the dif mounting stud.
I have tried pushing the bushing further out but then causes alignment issues with the ears of the differential. (Actually adjusting it three times...had to reinsert the bushing twice....)
Everything is torqued to spec.
Is this normal, will it affect anything?
Old Feb 4, 2018 | 07:28 AM
guitman32's Avatar
guitman32
You may try threading the stud a little farther into the cover which has been my fix, but the reality is it will ride fine like that.
Ive been through a few rear ends now, and I have noticed this wear pattern on the face of almost all of the differential covers where you can see that it was contacting the bushing at an angle.
Not saying its ideal, but it seems to be pretty normal and wont affect anything
Old Feb 4, 2018 | 07:32 AM
guitman32's Avatar
guitman32
Note I also run SPL bushings, sucks you had to re-insert so may times. You must be an expert by now
Old Feb 5, 2018 | 09:03 PM
terrasmak's Avatar
Drive for a day, retorque, it will pull it’s way into place after a day or two
Old Feb 6, 2018 | 11:22 PM
rottingcat's Avatar
rottingcat
I guess I can rest a little easy..SPL emailed back saying that as long as everything is torqued to spec it should be fine.
mleroux
Suspension
Jun 3, 2013 11:04 AM
bryan@Z1
Suspension
Jul 13, 2010 07:20 AM
