2003 350z engine start but bogs problem
Old May 13, 2018 | 09:43 PM
gfish618's Avatar
gfish618
Default 2003 350z engine start but bogs problem
Hi guys,
So I was leaving a stoplight in first gear and at around 4000 rpm's I decided to put my clutch in to shift. However, just as I took my foot off the gas and put the clutch in the car started to bog and shake a little and then eventually lost power steering then died. Once it started to bog I tried giving it gas and it seemed to keep the car from dying until it eventually gave out. Now when I try to start it, it turns over but immediatley goes to a low RPM bog and the gas pedal seems to do nothing before the engine dies.
Any help would be appreciated thanks.
EDIT: Also there is no check engine light
Old May 14, 2018 | 04:49 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Try resetting your ECU/ECM and see what happens(disconnect negative cable from battery, turn headlights on, pump brake pedal 15 times, wait 15 minutes, turn headlights off, reconnect negative cable to battery)... Also, do you hear your fuel pump prime itself(a 2 second hum coming from the rear) when you turn the key, before you crank it?
Old May 14, 2018 | 06:29 AM
gfish618's Avatar
gfish618
Thanks, and yes I for sure do hear the fuel pump priming when I turn my keys. I will try the ECM reset process in just a few.
Sang Min Sin
Jan 11, 2018 09:02 AM
lanceccs
Jan 30, 2012 12:22 PM
Jamhour
Jan 22, 2012 04:53 PM
backagain
Dec 23, 2004 12:50 PM
andypandy
Dec 10, 2004 04:35 PM
