Engine overheating
Old Dec 22, 2019 | 05:23 AM
Codyz33's Avatar
Codyz33
Default Engine overheating
So long story short I put a motor in my Z had the cooling system semi bled when I first did it I only had heat when driving not at idle, a week or two goes by I’m driving my car and I loose heat and temp shoots up. Got it towed home Put a new thermostat in it and did the bleeding process again, didn’t work tried both ways with the spill free funnel and FSM way my bottom hose is still cold. When I add coolant to the spill free funnel some will go down but it eventually coolant comes back up the funnel if anybody has any ideas please let me know im assuming there’s air in the bottom hose but I squeezed it I see it burping but hose remains cold??
Old Dec 22, 2019 | 08:17 AM
813_350Z's Avatar
813_350Z
Do fans kick on with your AC on full power?
Sure you have all of the air out 100%?
Old Dec 23, 2019 | 04:41 AM
masterjr33's Avatar
masterjr33
when it ges hot. feel the hoses to the radiator.
is one hot. and one cold?
Old Dec 23, 2019 | 07:00 AM
bealljk's Avatar
bealljk
your thermostat isn't opening … either it's dysfunctional or you have air bubbles behind it...
Keep bleeding … look into the lisle coolant funnel / bleeding system
Old Dec 23, 2019 | 08:16 AM
jhc's Avatar
jhc
General & Tech Moderator
IIRC the thred is called, "Burb."
yoshi350z
Feb 4, 2018 08:35 AM
neezebeeze
Jul 28, 2017 08:13 PM
JDMStanced
Mar 24, 2017 03:31 AM
Moe747
Jul 17, 2015 09:06 PM
alvear1311
Mar 27, 2015 12:42 PM
