Clogged PCV?
Old Jan 1, 2020 | 10:34 AM
Legendaryusei's Avatar
Legendaryusei
Default Clogged PCV?
but if it was clogged why would vacuum go down?
Old Jan 2, 2020 | 07:09 AM
jhc's Avatar
jhc
General & Tech Moderator
While I appreciate your technical abilities the way to diagnose this is still the old school method. Disconnect it and shake it. You should hear a metallic rattle. If yes, it's good, if not clean with brake cleaner or replace.
Old Jan 2, 2020 | 09:38 PM
Legendaryusei
i hear a rattle, and that should mean its good, ill replace because its a cheap part, but im still curious as to why vacuum jumps up when i create a leak
Old Jan 3, 2020 | 12:57 AM
jhc's Avatar
jhc
Good call. I watched with sound off. I'd imagine the engine is advancing the timing/rpms to prevent stalling. As rpms go up, vacuum goes up.
Z33Garage
21
Jan 17, 2021 09:53 AM
Villainous350z
Mid-Atlantic
Mar 28, 2013 10:35 AM
silverstone03
Videos
Dec 26, 2012 12:14 PM
