Car over heats, but coolant is cold when bleeding system.
Old Jan 27, 2020 | 04:38 AM
Dillonr24's Avatar
Dillonr24
Default Car over heats, but coolant is cold when bleeding system.
04 Z 149.5K miles
Engine starts to over heat when I turn heater on full blast. I can drive a 1/4 then it starts to over heat as soon as the fans kick in. Fans work and thermostat is replaced. There’s so much pressure in the radiator hoses then when I bleed the coolant system the coolant is as cold as ***. Both hoses are nice and hot though. Please help.
coolant does go down so it’s sucking it up, the reservoir starts to over flow a bit. No heat in the cabin either. When I take the bleeder valve off the coolant comes out hot but it’s cold at the radiator and comes out cold from bottom of the radiator when draining.
Old Jan 27, 2020 | 04:45 AM
travlee's Avatar
travlee
Master
dude, stick to your same thread you already started on this. like stated in the other thread, you prob still have air in the system
Old Jan 27, 2020 | 04:49 AM
Dillonr24's Avatar
Dillonr24
sorry wasn’t getting replies anymore so decided to make a new one to see if I get more replied about it.
Perezbrandon54
Oct 16, 2018 01:24 PM
yoshi350z
Feb 4, 2018 08:35 AM
AbbeyZ
Jul 18, 2017 07:23 AM
JDMStanced
Mar 24, 2017 03:31 AM
Floridaboy1605
Apr 7, 2008 06:22 PM
