Random missfire
Old May 2, 2020 | 09:14 AM
Giovannyv's Avatar
Giovannyv
Default Random missfire
So I Bought a 03 350, and lately its been having a random missfire. We already replaced all spark plugs gapped them then replaced the knock sensor and all plugs as well but keeps having the same problem car lags and doesn’t run at it full potential and occasionally it will die once I hit the red light. Have you guys experienced something similar and what did you guys end up doing. Thanks In advance
Old May 2, 2020 | 09:48 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Did you pull codes to determine “random misfire” or just your choice of words for its behavior?
P0300 = random misfire but if lucky, you’ll catch a P030x identifying the cylinder(s).
When you did the plugs, did you check/replace any ignition coils? 80% of the time, it’s a bad coil (or more) OR a misplacement of the #4 and #6 coilpack.
Old May 26, 2020 | 07:57 PM
Cracka350's Avatar
Cracka350
Mic, I've been fighting this code for the past year. I've replaced all of my coils and sanded the plugs then tried replacing camshaft position sensors, MAF sensor and tested for vacuum leaks using starter fluid. I get no reaction from starter fluid. This misfire is killing me. Any thoughts?
Old May 26, 2020 | 08:04 PM
MicVelo's Avatar
Is yours a generic P0300 or P030x identifying the culprit cylinder?
I would inspect the entire ignition harness at this point. (Start with checking the #4 and #6 cylinder wiring to make sure they're not switched.) With all the seemingly obvious fail points replaced, can only surmise it comes down to bad wiring.
Old May 26, 2020 | 08:18 PM
THIRZTY's Avatar
THIRZTY
Generic P0300 has a laundry list of possible causes in the FSM. Have you ran through all of them? Have you done a vacuum test? Or compression and leak down test? Weak cylinder(s) can trigger P0300. I rebuilt my engine over it... 60% leakdown in like 3 cylinders.
tmdz
Sep 25, 2017 09:54 PM
Noodlez
Jul 26, 2016 10:50 AM
ctanakaya
Jan 6, 2016 12:15 PM
Cspears1411
Sep 30, 2013 10:32 AM
Jurgen
Jul 6, 2013 05:39 PM
