DE misfire problem
Old Dec 28, 2020 | 06:22 AM
Cody Pulscher's Avatar
Cody Pulscher
Default DE misfire problem
I’m having a weird misfire problem with one of my cylinders, I’ve replaced the coil packs and spark plugsand cleaned the maf sensor multiple times . It will be running and driving fine but once it starts to get warm or goes above 70 the cylinder starts misfiring. If anyone has some guesses to what it could be it would be appreciated. It has 140,000 miles.
Old Dec 28, 2020 | 09:54 AM
Cody Pulscher
just did a compression test everything was fine, also checked the cylinder heads and all but 1 are super black and oily.
Old Dec 28, 2020 | 10:34 AM
travlee's Avatar
travlee
Master
make sure you have the coil pack plugs correct, there are 2 that are easily swapped by mistake
Old Dec 28, 2020 | 10:52 AM
Cody Pulscher
Will do, is it possible for too much oil Ina cylinder to cause it too bog from a bad valve seal?
Vora
Engine Swaps
Jul 18, 2017 10:52 AM
mazzotta.al
Aug 25, 2016 05:27 PM
LeonardiZ
May 13, 2015 08:06 PM
KDW2002
Jul 16, 2006 05:13 AM
