Timing chain is still rattling after changing primary timing tensioners
Old Nov 29, 2022 | 08:41 AM
riproach's Avatar
riproach
Default Timing chain is still rattling after changing primary timing tensioners
I had the timing chain rattle on start up but just this past weekend I had changed the primary timing chain tensioner which everyone on forums had said but after installing the new timing chain tensioner it still rattle and i just want to know what else could it be?
Old Nov 30, 2022 | 04:19 PM
Conway_160's Avatar
Conway_160
Did you happen to change your timing chain as well? Maybe it stretched (unlikely) and the tensioner is not long enough to get proper tension.
What is your oil pressure, is it high enough to fully extend the tensioner?
Did you check the bolts on the guides to ensure they are not loose and rattling?
Old Dec 1, 2022 | 02:19 PM
riproach's Avatar
riproach
thank you for the reply I actually didn’t take the timing cover off so I wasn’t able to inspect the guide or the chain but thank you I will look over the whole timing assembly
StephenM57
Mar 26, 2019 07:23 PM
Thefbomb13
Jan 30, 2018 10:39 AM
kurtzd
Sep 10, 2014 10:23 AM
specialist
Aug 25, 2009 01:57 PM
moog
Jan 27, 2004 09:57 PM
