Thermostat not opening after changing it
Old Jan 7, 2023 | 12:11 PM
Hec_sot's Avatar
Hec_sot
Default Thermostat not opening after changing it
I have a 03’ 350z and I just bought a thermostat directly from the dealership and replaced it, started the bleeding procedure but the thermostat seems to not open and fans just stay running loud. The lower hose going into the thermostat is cold while trying to burp the system.
Old Apr 24, 2023 | 06:43 AM
Ulery53's Avatar
Ulery53
Next time test the thermostat before installing boil water in a pan and put the thermostat in if it doesn't open its bad and it has happened to me also these thermostats are not the easiest to swap hope this helps
Old Apr 24, 2023 | 07:05 AM
i8acobra's Avatar
i8acobra
When the car is cold and you start it, do the fans come on right away? Why did you replace the thermostat? Was your gauge pegged hot? You probably have a bad temp sensor if the answer is yes to the first and third questions.
Old Apr 24, 2023 | 10:47 AM
Hec_sot's Avatar
Hec_sot
Never mind I just had to bleed the system several times and it worked now
Kuroshiito
May 26, 2019 03:34 PM
yoshi350z
Feb 4, 2018 08:35 AM
built-z
NA Builds
Apr 18, 2011 11:53 AM
camthman
Nov 21, 2008 09:30 AM
