throttle position sensor
Old Mar 11, 2004 | 03:22 PM
03G35s's Avatar
03G35s
Default throttle position sensor
I hooked up my G35 6MT sedan to a OBD-II data logger to check out what was going on and to compare intake air temps using pop charger with a stock G. I logged about an hour's worth of driving. While doing this I found that the maximum throttle position I ever recorded was 86% (even with a long period of WOT, starting at low RPM in 6th gear). My question for others that have monitored their ODB-II data on their Z or G is: "is that normal"... or should I actually see 100% at WOT?
Thanks.
Old Mar 11, 2004 | 03:31 PM
jesseenglish's Avatar
jesseenglish
There are a couple threads on here. To answer your question. They all saw the same thing.
Old Mar 11, 2004 | 04:15 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
i wish i would have checked this before my TS update... i can tell you that after the TS flash, I get 100% all the time...
hth,
m
Old Mar 12, 2004 | 04:32 AM
03G35s's Avatar
03G35s
I did a search before posting and found one thread that discussed it but didnt have much detail. I believe it was zzzya that posted:
Have there actually been cases in the past where Nissan cars have had the throttle body *not* open 100% when the pedal is pressed all the way down?? [/B]
Yes, the 350Z! It is already known that the throttle body does not open up 100%. This is controlled by the ECU and Technosquare has fixed this issue with their ECU upgrade among other things for $599. I have strongly considered getting the Technosquare upgrade but would rather have something I can tune myself someday.
It didn't say whether 86% was normal or 99% or what. I was searching for "throttle position sensor obd." If there is a thread that says more, please point me to it.
Old Mar 12, 2004 | 04:45 AM
jesseenglish
Can't seem to find the other one, but I know there were at least two threads.
https://my350z.com/forum/showthread....threadid=39299
During full throttle runs, I never exceed 82% full throttle.
I know there was at least one more, and the best another member could get was in the 80%'s also.
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
