Clutch Combos?
Old Mar 25, 2004 | 08:11 PM
3rdpower's Avatar
3rdpower
Question Clutch Combos?
Can you use lets say JUN flywheel with JWT clutch and presure plate? I have the JUN flywheel and considering JWT's combo to match with JUN. Big difference between Nismo and JWT (obvious a bit more holding power on the JWT side). Thanks in advance for all advice. BTW, SC or TT is in the future.
Old Mar 26, 2004 | 06:04 AM
3rdpower's Avatar
3rdpower
Default bump
Bumper
Old Mar 26, 2004 | 09:35 AM
3rdpower's Avatar
3rdpower
Just called JWT and found out myself - clutch and Pressure plate and standard as stock so you can use another flywheel that works w/ stock.
Old Mar 26, 2004 | 03:00 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
You can use the JWT Clutch with any flywheel that will work with the OEM Clutch...
You can use the JWT flywheel with any clutch that will use the OEM flywheel...
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
