Differential fluid & quantity?
Old Mar 29, 2004 | 06:09 AM
Z CRUZN's Avatar
Z CRUZN
Default Differential fluid & quantity?
Getting ready to change the diff oil to Redline Syn. 75w90 - how much does it take? Redline already had LSD additive in it, but have heard good things about the GM LSD additive. Any input? Thanks!
Old Mar 29, 2004 | 07:35 AM
Audito350Z's Avatar
Audito350Z
I used the Redline at my last diff oil swap... good stuff. You need two 1-quart bottles.... I used one whole bottle and about 1/8th of a second bottle to top off the diff.
Cheers,
PeteH
Old Mar 29, 2004 | 07:41 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I use Royal Purple 75w90, it takes about 1 1/2 qts.
Old Mar 30, 2004 | 06:05 AM
mwaller's Avatar
mwaller
As others have said, you'll need to buy 2 quarts, but you'll only use about 1/2 of the second bottle (or less)
No need to add more additives, unless you have an aftermarket clutch-type differential. then additives can be used to 'tune' it.
Mika
Old Mar 30, 2004 | 06:10 AM
D@ActiveTuning's Avatar
D@ActiveTuning
How often should you change the LSD fliid?
Old Mar 30, 2004 | 06:34 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I change mine at 30k, but after I drained it, it still looks clean to me. So I think it can last a lot longer.. maybe 50k?
Old Mar 30, 2004 | 07:28 AM
mwaller's Avatar
mwaller
I'd do it every 30K. I just replaced my fluid for the second time at 30K (1st time at 5K to remove break-in debris) and it was already murky looking. I used Redline 75W90 both times.
Mika
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
