Jdm Ecu
Old Mar 31, 2004 | 12:22 PM
GY-Z's Avatar
GY-Z
Default Jdm Ecu
if we use JDM ECU on our car, what most likely will be the problem?
octane level?
anything else?
Old Mar 31, 2004 | 01:02 PM
zillinois's Avatar
zillinois
Your car won't start. Somebody already tried it.
Old Mar 31, 2004 | 01:05 PM
zfastest's Avatar
zfastest
Default Re: Jdm Ecu
octane level?
anything else?
Why would you do this? Does the US version cause frequent lockups, causing you to reboot often...or no wait...I'm thinking of windows....?
Old Mar 31, 2004 | 01:31 PM
baptist's Avatar
baptist
Is that with cookies enabled???
Old Mar 31, 2004 | 01:50 PM
ypwpat's Avatar
ypwpat
is it with Anti-Virus software too?
Old Mar 31, 2004 | 04:13 PM
GY-Z's Avatar
GY-Z
can anyone specify why?
thanks
Old Mar 31, 2004 | 04:40 PM
zillinois's Avatar
zillinois
I think the only thing of value would be the maps. And they would have to be translated or changed to reflect the different inputs due to measuring unit differences etc. Technosquare and others offer those maps so most people just buy it from them.
Old Mar 31, 2004 | 04:56 PM
isugoo's Avatar
isugoo
ecu Z recognizes serial# and only work with your serial#. in case you wanna upgrade your ecu, you have to take out from your car send to the place to upgrade and put back in to make car work.
there is no way to replace jdm or aftermarket ecu other than sending your ecu to upgrade as long as i know.
Old Mar 31, 2004 | 04:59 PM
GY-Z's Avatar
GY-Z
i am confused here, so ur saying if i send my stock ecu to Jap, then the ecu their selling will work on my car?
Old Mar 31, 2004 | 06:12 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Your ecu is coded to your key. You cannot buy an ecu from any JDM tuner and plug it in - it will not work unless it's specifically programmed to work with your key.
More importantly, why on earth would you bother?
Old Mar 31, 2004 | 06:33 PM
zillinois's Avatar
zillinois
Look in the Australian area for the guys who tried it. They just weren't compatible. I thought maybe the JDM ecu looks for say cubic meter per minute and the US spec sensors would send cfm? I don't know.
Old Mar 31, 2004 | 07:16 PM
Michael-Dallas's Avatar
Michael-Dallas
That's BS. When you replace your ECM, you must register your keys w/ the new ECM. For more details, I defer you to the FSM, BL-122, "ECM Re-communicating Function."
droideka should know more considering he's had to replace 2 ECM's under warranty since last year.
Michael.
Old Mar 31, 2004 | 09:32 PM
apsilon's Avatar
apsilon
Just to clarify the one that was tried here was a JDM car imported for racing use. They swapped in an ECU from a locally delivered car and it wouldn't start. I presume due to the security key issue but I don't know for certain.
Old Apr 1, 2004 | 12:08 AM
GY-Z's Avatar
GY-Z
so what if i send my ecu down to the JDM tuner ?
will it work?
Old Apr 1, 2004 | 12:09 AM
GY-Z's Avatar
GY-Z
so thatz a JDM z with a US spec ECU?
confused...
GY-Z's Avatar
GY-Z
Michael.
can u be more specific?
thanks
Old Apr 1, 2004 | 12:27 AM
apsilon's Avatar
apsilon
confused...
No a JDM Zed that tried an Australian ECU.
Old Apr 1, 2004 | 01:20 AM
Z350Lover's Avatar
Z350Lover
"FairLady in Japan" he has Nismo ECM in his car and what I heard from him is that he has a direct swap instead of getting the standard ECM remapped though. So does that mean all the JDM don't have the key mapped to the ECU?
cheers,
richie
Old Apr 1, 2004 | 02:19 AM
apsilon's Avatar
apsilon
I thought the Nismo ECU in Japan was actually a remap of the stock ECU? I seem to recall someone posting it was done this way so it couldn't be copied, ie you have to go to a dealer and have them flash it. Didn't sound right to me as you could buy one then copy it anyway with the right tools but who knows.
Old Apr 1, 2004 | 02:55 AM
zillinois's Avatar
zillinois
So a JDM ECU could be used if the key was coded in? I bought a spare ECU so I could have it reflashed. I had Technosquare reflash it and and copy the security code from my factory one and everything works fine. My spare is US spec though. Would be interesting to see if it worked with JDM.
