Best Bang for the buck mods for an Automatic
Originally posted by MrDemon
i would sell it asap and get a manual
why by an auto then mod it ????
D
D
Would you mind telling all of us, (AT and MT drivers) why we should sell all the ATs and go with MTs and also why we shouldn't mod it. Real answers please and none of your elitist opinions passed on as wanna-be facts.
Originally posted by Grey Matter
I would also recommend the JWT PopCharger. It was my first mod along with a grounding kit.
I have a list of recommendations but none of it matters if you can't afford it. What kind of budget are we talking about here? After all the money I have spent, if I had to start over I would say go SC right from the start. Get the Vortec setup and you will not be disappointed. You could always get a new exhaust later to add more HP. I got the bug and started spending money on mods that helped but really do not even come close to what FI is doing. If I would have saved from the start I would have FI now and be much happier. The aftermarket mods are simply too expensive still and N/A is proving that little gains are to be had here and there which requires $$$$$. With FI you will seriously know you have made gains. The only mod I can recommend right off the start is the Crawford Plenum. It will open up the top end that is so weak in stock form. It is FI ready and will help to create even air/fuel to all cylinders preventing carbon build-up on pistons and valves whether you are N/A or FI.
Originally posted by Aggro_Al
Best bang for the buck on an AT would be a High-Stall Torque Converter. Cost would be between $500-$1000 for the TC and installation. You can significantly improve your times w/o affecting daily driving too much if you set it up right.
A stall converter will not get you much in the way of better numbers without going a little wild which would require some really good tires to get any traction. A better mod for the 5AT regarding 1/4 mile times, track times and street racing would be a different rear end. You would loose a littel in the gas mileage for normal everyday highway driving but you would get into the "powerband" of the engine much faster and stay there much easier. If one stays N/A this would be real performance booster, if one goes FI, then you would want to keep the stock rear end since you would have a much larger "powerband".
You don't have to go really wild with a high stall torque converter to see improvements. Torque converters can be tuned to meet specifc needs. If you wanted to get the fastest off the line speed then you would set the stall speed very high. Doing that would ruin your daily driving because you would be at maximum torque the moment you let your foot off the brake and your gas mileage would go to hell. If you wanted to improve performance efficiency a mild bump up in stall speed would be helpful. I still think that a high stall torque converter properly tuned is the best bang for the buck for a naturally aspirated ATs. If you also go FI, they would complement each other well. Here's some info on high stall torque converters. For less than a set of new tires you can see some serious performance gains.
http://www.bankspower.com/Tech_understandstallspeed.cfm
http://www.edgeracingconverters.com/WhatisStall.htm
Mr.Demon,
I haven't lost in the 1/4 mile yet to a manual and just this past weekend raced a guy at the track and we both had the same mods and guess what, I beat him 3 times. So much for selling my 5AT.
Originally posted by coachk
Mr. D
Also we were both very experienced at racing so you can't blame it on his driving.
Mr. D
What way did you find faster? Like I said, it feels faster in manual mode, but I can't believe that I can beat a computer shift, especially one fitted to a high performance car that will shift aggressively.
Mr.Demon,
Mr.Demon,
IT must be some thing about US driver and auto's, why do you like em so much ?
YOu lot go on about it being a drivers car then dont even know how to change gear lol then you only track em in straight lines
next you will want auto steering , tee hee
I just dont get it.
Every car mag in the UK slates the Auto and every one knows it slower and weighs more.
d
I just dont get it.
d
Originally posted by 2004LeMansZ
Hello Everyone,
I would like to start off by saying hello to everyone on this board. I have had the Z for about two months now and just now got around to posting on this board. I was wondering what mods are the best bang for the buck. I want the most power without going to crazy with N20 or forced induction. Most of the searches I did only show power gains on cars with 6 speed manual transmissions.
Am just happy with this car.
Thanks for all the help.
Hello Everyone,
Sell it and get a 6MT
I just dont get it.
d
I just dont get it.
d
You're right you just don't get it. Check your specs again. Nissan's website lists the weight of the 350Z Enthu AT as 3,210 lbs and the 350Z Track MT as 3,225 lbs. I didn't get a chance to convert these numbers to kilograms but I'm pretty sure that the AT would be lighter than the MT in kilos unless the laws of physics are different in the UK. As far as performance, the cars are evenly matched. It will come down to driver skill.
Why do you think that because we have an auto that we can't drive a stick? I can drive a stick and I have an auto and I'm sure there are others. Even if they can't drive a stick why would it matter to you. If they enjoy driving an AT more power to them. My "opinion" is that a sports car should be performance orientated fun. I don't think that the type of transmission defines if it is a sports car or not.
You still haven't told us why we should sell all the ATs and buy MTs. We await your comment.
