VK45DE in the Z
Old May 16, 2004 | 05:26 PM
UnKnownClient's Avatar
UnKnownClient
Default VK45DE in the Z
I had a thought when I saw the FX45, with its VK45DE V8 and the same FM chassis this engine should fit in the Z. Has anyone seen this conversion done yet? This mod could be an alternative to stroking the VQ35DE. Find a totaled FX45 and take the engine out
Old May 16, 2004 | 05:35 PM
DuckyZgiirl's Avatar
DuckyZgiirl
you mean the VK45 fix the title it will work but handling wont be soo good
Old May 16, 2004 | 05:50 PM
UnKnownClient
Thanks for the update on the name of the motor. I could see how the added weight would affect handling, but couldnt a different suspension system help reduce the effect of added weight? Plus just wondering if anyone would think of doing this kind of mod.
Old May 16, 2004 | 06:38 PM
PhoenixINX's Avatar
PhoenixINX
Why won't the handling be any good?
If you were smart in the install you'd push the motor as far back as you can, up against the firewall. Then run the intake side to the front.
In theory it would work VERY well. My concern would be width... Not sure if it would slide in too well.
Old May 16, 2004 | 06:56 PM
DuckyZgiirl
The fit is not the problem its the weight. Ruinds handling. You will need to get the fron suspension and sways of the FX45 if it can fit or the upcoming M45.
Old May 17, 2004 | 03:32 AM
kudos's Avatar
kudos
Top Secret is workng on a conversion, but they are putting it in a G35 and they are putting in a little more than what you hoped for. Check it out its in the web site, first article. http://www.topsecretjpn.com/topsecretenglish.html
tilleys99
Jan 9, 2007 10:38 AM
jasonrburke
Jan 1, 2006 11:27 PM
