My Crank Pulley Dyno Results....
I think the pulley is great. Throttle response is better and the car feels lighter. That being said, mine will be coming off after only 200 or so miles. Gotta get the stock ratio for the Vortec kit.
Anyone need a red, BARELY used UR pulley?
Originally posted by Jason@Performance
how long ago was your last pull? its hotter out now..
Originally posted by zxsaint
Pulley affects a/f? ECU is load-based??
I think this thread is becoming a great candidate for the ultimate misinformation thread.
Ok.. my turn: "The world is flat."
As far as the numbers go, I wouldn't consider any dyno accurate within 10rwhp over a timespan of 1 month. SAE also uses a formula to adjust the numbers based on temp/alt/etc. Not entirely accurate either, especially considering the dynojet operater can adjust this at any time during calibration. You could have easily made 5-7 and not show it due to the # of factors involved. The only way to really use a dyno accurately is to redyno the same day or at least within the same week to get an idea.
Also, are you running the exact same wheels/tires as your baseline?
Lets take a look at the chart...
Alberto said he wasn't going to post the results.
Oh, and the world isn't just flat, it also happens to be a cube.
ZXSaint, I used the same wheels/tires as the first time. I always dyno at this place, and if 1 month or 4 months goes by when I dyno there, if the part makes power I get results, if it makes very little, as I was shocked when I dynoed the AEM/Crawford plenum, then it shows as well. I can email you my dynos if you would like I have no host to post the graphs, but I will email you and you can post if you'd like....
Sure, got the winpep file by any chance?
That way I can lay it on top of various other Z dyno charts that have a similar combination of mods (including pulley) to look for any common trends. I've made some interesting discoveries with this method.
I have U/R Pulleys and KINETIX Cats (as well as a few other things). It seems as though the power that I originally felt when I installed the mods has gradually diminished over time. Keep in mind that this is strictly my Butt-dyno reading. I am going to the Dyno Day on the 12th to get my "real" dyno reading to compare against my baseline numbers (which you can see along with the graph in my sig). The base was done with just a grounding kit and K&N drop-in filter. I'm anxious to see what type of increase I get with my current mods (including the pulleys).
-Chris
-Chris
Originally posted by Static
The true test would be for you to take off the pulley and redyno your car.
Originally posted by Alberto
Man some of you guys are never happy. I've spent $240 in the past few months for dyno time, to dyno all my petty N/A mods, I am not going back to the dyno for a long time. The true test for me was last Saturday, and the pulley failed in my gradebook. It also failed @ the track where my traps were the same as before the pulley, actually slightly lower, so sorry guys. For those of you with the pulley good luck. ZXSaint I'm not sure what type of file I have, they are saved on a disk from the dyno place. I use the Dynojet runviewer to see them....whats your email I'll send you some dyno's.
first of all your trap speed is not an indicator of your hp. second you are the first i have seen that has not gotten any gains from the ur pulley thats why we have a hard time swallowing it. personally from my experience i felt the pulleys make a difference but it took about a week before i felt all of the gains.
