TILTON Carbon Carbon 2 Disc Clutch EXPOZED!
Old Jun 9, 2004 | 09:05 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Cool TILTON Carbon Carbon 2 Disc Clutch EXPOZED!
OMFG and WOWZERS was all I could say when I opened this piece up.
This is the 2 disc carbon carbon tilton clutch...
It is a 7.25" Clutch for use with the 8lb Tilton Flywheels...
They make 1 / 2 / 3 disc 7.25" clutches...
1 disc handles 310ft-Lbs Torque to the wheels
2 disc handles 620ft-Lbs Torque to the wheels
3 disc handles 930ft-Lbs Torque to the wheels
(same HP ratings for the ceramatallic disc clutches)
4 disc metallic holds 1240HP!!!!
The carbon carbon clutch disc's are made completely out of carbon so are very light weight and have over 20lbs-in squred Moment of Inertia value.
Basicly, if you thought my car reved fast with the 2 cerametallic disk clutch, wait till you see this!
How will this clutch perform...
It will rev just as fast as seen with my Rally / Race set up with the 8lb Flywheel and 2 disc cerametallic clutch but you will beable to slip the clutchwhen starting from a stop or going up hill or inching your way though traffic.
If you want the performance of the tilton and want streetablity and dont want to worry about a super grabby clutch, think about this piece...
Below are some photos of the 2 disc version. It as 2 disc's and 3 plates... all carbon carbon...
well.. i will let the pictures talk...
Attached Thumbnails TILTON Carbon Carbon 2 Disc Clutch EXPOZED!-img_3546.jpg
Old Jun 9, 2004 | 09:07 PM
Jason@Performance
Performance Nissan
Attached Thumbnails TILTON Carbon Carbon 2 Disc Clutch EXPOZED!-img_3547.jpg
o snap its eric's Avatar
o snap its eric
OMGF and WOWZERS concerning prices tooo!
Old Jun 9, 2004 | 09:08 PM
Jason@Performance
Performance Nissan
Attached Thumbnails TILTON Carbon Carbon 2 Disc Clutch EXPOZED!-img_3548.jpg
Old Jun 9, 2004 | 09:10 PM
Jason@Performance
Performance Nissan
It is a life of the car clutch...
and the flywheel can be resurfaced...
and if the clutch goes out on your, it is remanufactured by tilton...
I need to check on something else and confirm before I say it... Ill put it in this thread tommorow...
Attached Thumbnails TILTON Carbon Carbon 2 Disc Clutch EXPOZED!-img_3549.jpg
Old Jun 9, 2004 | 09:11 PM
Jason@Performance
Performance Nissan
Attached Thumbnails TILTON Carbon Carbon 2 Disc Clutch EXPOZED!-img_3552.jpg
Old Jun 9, 2004 | 09:12 PM
Jason@Performance
Performance Nissan
Attached Thumbnails TILTON Carbon Carbon 2 Disc Clutch EXPOZED!-img_3553.jpg
Old Jun 10, 2004 | 08:53 AM
DeeZee's Avatar
DeeZee
Old Jun 10, 2004 | 09:03 AM
JeffR116's Avatar
JeffR116
Wow! That is absolutely beautiful. Of course, It better be for the price. Although, $3k might be a worthwhile investment considering its wear/power capabilities.
Old Jun 10, 2004 | 09:32 AM
ACEMAN's Avatar
ACEMAN
Master
How much HP is recovered using this setup up? This setup should really reduce the amount of DT loss there is on are cars. If the stock setup weighs in at 66 lbs and this setup is only 16 total lbs, that should make a noticable difference.
So how much do you think is freed up??
Laterz
Aceman
Old Jun 10, 2004 | 01:09 PM
Jason@Performance
Performance Nissan
the 2 disc carbon carbon clutch is NOT 3375... That is the 3 disc carbon carbon...
The clutch pictured is...
$2850 around...
Old Jun 10, 2004 | 01:38 PM
drudacris27's Avatar
drudacris27
great now I gotta save up for that too. Sweet clutch. Are you going to install that on your car?
Old Jun 10, 2004 | 01:44 PM
Jason@Performance
Performance Nissan
there is a 30HP Increase in power to the wheels during acceleration... it doesnt add peak HP but I have had customers say it added a few... but who knows...
Old Jun 10, 2004 | 02:14 PM
teh215's Avatar
teh215
That is too good looking to hide in a bell housing
Old Jun 10, 2004 | 02:42 PM
NismoKid's Avatar
NismoKid
I need now!!1!!111!
Jason, is there going to be a less expensive tilton compatible clutch that can be feathered as the carbon carbon ones? Thanks in advance.
Old Jun 10, 2004 | 03:04 PM
Jason@Performance
Performance Nissan
you can use a single disk carbon carbon clutch but i wouldnt recomend it for long term durability...
you can slip the current cerametallic disc clutch i am running in my car now... that package is $1310 including flywheel...
Old Jun 10, 2004 | 05:19 PM
jreiter's Avatar
jreiter
What is the drawback to running the 3-disc clutch vs the 2-disc clutch? (Other than price, of course.)
Does the 3-disc slip differently? Any negatives?
Old Jun 10, 2004 | 06:13 PM
zillinois's Avatar
zillinois
My precious!
Old Jun 10, 2004 | 07:01 PM
Jason@Performance
Performance Nissan
3disc will engauge quicker and be a little more grabby... plus will last a little longer and be more durable...
Old Jun 10, 2004 | 08:19 PM
ranger5oh's Avatar
ranger5oh
What is the point of multiple discs? How does that even work? Does each disc slip on each other?
So $3k for a clutch huh? Yowzers...
