leaking liquid
Old Jul 26, 2004 | 05:33 PM
kws's Avatar
kws
Default leaking liquid
had leaking liquid(the liquid smell like a water, i don't it is water or not) from my Z front right side bottem when i switch on the A/C
the location around the front right side, behind the right front wheel.
had any owner had this problem???????
Old Jul 26, 2004 | 05:53 PM
yobri's Avatar
yobri
Most likely condensation... happens to virtually all cars with the AC on for prolonged periods of time. I wouldn't worry if you said it smelled like water
Old Jul 26, 2004 | 06:06 PM
kws's Avatar
kws
do u had this problem?
Old Jul 26, 2004 | 06:16 PM
yobri's Avatar
yobri
I have with other cars, but the Z is my weekend car and I don't find much need to activate the AC for anything longer than 10 minutes at any particular time. I've seen this plenty on SUVs as the clearance view underneath is easily visible (that is, without having to bend over to look)
Old Jul 26, 2004 | 06:24 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It's most likey water KWS. If you run your AC a lot, the cold temp of the AC unit causes moisture in the air to condense and drip down. I get this all the time when I run the AC on high for a good length of time.
Old Jul 26, 2004 | 08:14 PM
ares's Avatar
ares
Veteran
youve never seen this before? is it cold all year in canada or what? around here youll see a full puddle after just stopping at a redlight.
if its not oil, and its not antifreeze, neither very easily confused with water, I dont think you have any worries.
Old Jul 27, 2004 | 04:38 PM
Steel Heals's Avatar
Steel Heals
I get the same thing...comes from behind the R front wheel. I'm pretty sure it's just condensation from the A/C. No worries.
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
