Nismo or Borla
Old Oct 3, 2004 | 01:19 PM
cains10's Avatar
cains10
Default Nismo or Borla
Nismo vs Borla single or dual exhaust for a ZR. Any opinions out there?
Old Oct 3, 2004 | 02:35 PM
DavesZ#3's Avatar
DavesZ#3
They're both about the same as far as HP/Tq gained. Each has advantages and disadvantages.
While Nismo is single pipe, it is 60% larger than stock so you do get more exhaust flow. Nismo is only three pieces, Borla about 17. Borla install is more difficult. Nismo cost more.
Do a search as this subject has been discussed ad-naseum.
Old Oct 3, 2004 | 02:49 PM
Hazade's Avatar
Hazade
my vote is for the borla TD. it has a great sound and its cheaper
Old Oct 4, 2004 | 02:56 AM
Sz28r's Avatar
Sz28r
My vote = Nismo
Exhaust Shootout notes:
They used two cars (2% Hp difference).
Car 1 Baseline = 233.2 Hp - 222.6 ft/lbs torque
Car 2 Baseline = 237.5 Hp - 224.0 ft/lbs torque (stronger engine - lighter wheels)
All manufacturer's systems Hp and torque numbers were lower than advertised. Not a surprise.
Borla (car 2) = 8.2 Hp - 2.7 ft/lbs torque (peak values)
A top end system. Little HP increase until the 5600 rpm to 6500 rpm range. Lost HP & torque below 1800 rpm. 60mm (error actually 58mm). Weighs 52lbs. 1 million mile warranty. Installation - Hard (17 pieces)
5Zigen (car 2) = (-3.4) Hp - .02 ft/lbs torque (peak values)
Lost Hp, no real torque gain. Most expensive. Loudest. 58mm pipe. Lightest @ 25lbs. 1 year Warranty. Installation - Medium
Stillen (car 1) = 8.1 Hp - 7.3 ft/lbs torque (peak values)
Hp and torque increase starting at 3000 rpm to redline. Lost a little HP & torque below 1800 rpm. 60mm pipe. 74lbs - 10lbs heavier than the stock system. Lifetime Limited Warranty. Installation - Easy
Injen (car 1) = 7.6 Hp - 5.1 ft/lbs torque (peak values)
Small torque loss at 2800 rpm. Torque gain starts at 3300 rpm. Small Hp increase starts at 3300 rpm, max Hp from 5800 rpm to redline. Major loss in Hp and torque below 2200 rpm. 49lbs.
1 year Warranty. Installation – Easy
Nismo (car 1) = 6.3 Hp - 4.5 ft/lbs torque (peak values)
Torque increase starting at 3000 rpm. HP increase 4800 rpm to redline. No power losses below 1800 rpm. 54lbs. 3 years, 36K miles id installed by Nissan dealer. Installation - Easy
Exhaust sound clips:
http://www.everything350z.com/exhaust.html
Old Oct 4, 2004 | 03:21 AM
NY 350Z's Avatar
NY 350Z
sz28r - how do you think nismo would sound with test pipes? any rasp?
JjL
East Canada
Jun 12, 2019 03:04 AM
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
