Calling Dyno/Mod Experts
Old Oct 20, 2004 | 09:31 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Exclamation Calling Dyno/Mod Experts
People with FIRST HAND experience only please!
What type of gains should I expect at the wheels with:
JWT Popcharger
Crawford Cats
Lightened Flywheel
UR Crank Pulley
I dont want to search I just want up to date BRUTAL honesty
Also how much should I expect these mods to impact my 1/4 mile times if any. Ive been resisting the NA mod bug for almost a year now but I have a feeling its about to hit bad!
Old Oct 20, 2004 | 09:56 PM
murrman100's Avatar
murrman100
The math says about 20+ hp.
Reality says about 10+ maybe 12+ hp.
Not much more than .7 sec in the 1/4 mile. Depends on the driver also.
Best bet is to get it dynoed for the truth.
That damn bug bite hurts but you have to scratch it.
Old Oct 20, 2004 | 10:10 PM
EnthuZiast's Avatar
EnthuZiast
thanks! Im am itching right now
anyone else? How about driveability and affect of the power bang/dyno curve itself?
Old Oct 20, 2004 | 11:54 PM
GY-Z's Avatar
GY-Z
i'd say no more then 15whp.
area under the power band should increase a little bite, depends on how light your flywheel is.
Old Oct 21, 2004 | 04:44 AM
TheBigShow's Avatar
TheBigShow
no way in hell.
Old Oct 21, 2004 | 06:35 AM
ACEMAN's Avatar
ACEMAN
Master
With those mods you are looking at around 10-15HP thats assuming that stock dyno number is 235 to the wheels. Here is my dyno with all the mods in my sig. I made around 30HP extra.
Different mods will very in results with HP and TQ. If i would of went with crawford headers i think i would of made alittle more. NOt sure how much.
You want to add a ECU reflash in there to take advantage of those mods. As you see from my dyno i made 10HP and 9TQ with the addition of the ECU reflash.
SO all the mods in my sig only netted me 20HP
OH well
Laterz
Aceman
Old Oct 21, 2004 | 06:50 AM
EnthuZiast's Avatar
EnthuZiast
Thanks Aceman.
Old Oct 21, 2004 | 03:14 PM
zzzya's Avatar
zzzya
Aceman, did you modify your AEM intake? If not that could be hurting you as the standard AEM setup has been shown to be worthless and actually have a negative affect as you add more mods.
As for the original post, I would also say 10-15HP and maybe 0.2-0.3 sec off the 1/4 mile mainly because of the flywheel. I would recommend a plenum over the UR crank pulley especially since you want to go with a lighter flywheel. The plenum is something everyone should have to allow more even air/fuel to all the cylinders. It will also help quite a bit in the upper rpms and give your car a better overall exhaust tone. I have even heard that Nissan is interested is the Crawford design since the stock plenum does restrict air flow to the front cylinders.
Old Oct 21, 2004 | 08:48 PM
EnthuZiast's Avatar
EnthuZiast
the flywheel mostly improves 0-60 times correct?
How many hours of labor does it take to install one of those bad boys?
IS it a warranty voider?
Old Oct 21, 2004 | 09:26 PM
murrman100's Avatar
murrman100
If the dealer does it as a replacement, then it won't void the warranty. After that, its up to the dealer. SOL most of the time.
Old Oct 21, 2004 | 11:26 PM
EnthuZiast's Avatar
EnthuZiast
thanks..what about 0-60 times and labor hours?
Old Oct 22, 2004 | 06:48 PM
EnthuZiast's Avatar
EnthuZiast
anyone?
Old Oct 22, 2004 | 08:34 PM
murrman100's Avatar
murrman100
anyone?
Labor hours? That depends on your dealership. Usually about 7 to 9 at about 70$/hr. I'm being very liberal about that.
0-60 times? That depends on the other mods, the driver and the weight that you reduced on the car itself.
Cool?!
Old Oct 22, 2004 | 11:28 PM
EnthuZiast's Avatar
EnthuZiast
thanks..I guess I was just looking for #s and reactions from ppl who have the setup.
I dont want to do it unless I notice a BIG change.
Old Oct 22, 2004 | 11:49 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
Default ...
Aceman,
Did they do the inductive rpm pickup right on your runs? The graph looks like rpm pickup was setup wrong...
Gary
Old Oct 23, 2004 | 01:29 PM
ACEMAN's Avatar
ACEMAN
Master
anyone?
EnthuZiast
As you see from my sig i ran a 13.6 with Flywheel and AEM intake only. I have a Base 350z, so only one tire spins so i think thats a pretty good difference.
As far as price, i paid 420 for the flywheel and around 350 for install. I like haveing the flywheel, took some getting use to at first. But its just like when you buy a new car, takes awhile to get use to it aswell
Laterz
Aceman
Old Oct 23, 2004 | 01:31 PM
ACEMAN's Avatar
ACEMAN
Master
Default Re: ...
Originally posted by Gruppe-S
Aceman,
Gary
Im not sure what you mean by inductive rpm pickup. This was my first and only time at the dyno so it was all new to me. I assume he did, when you look at the dyno plot what do you see that makes you feel this way?
Laterz
Aceman
Old Oct 23, 2004 | 02:57 PM
EnthuZiast's Avatar
EnthuZiast
aceman...could you tell me how it feels different.
What do you think you would do to your time if you got a NISMO clutch as well?
Old Oct 23, 2004 | 03:05 PM
EnthuZiast's Avatar
EnthuZiast
Also I was hoping to gain more oomph in 1st and second.
Does it make the car pull much harder?
Old Oct 24, 2004 | 03:30 PM
ACEMAN's Avatar
ACEMAN
Master
Zzzya
Yeah, i turned my AEM CAI into a short version. I just removed the bottom pipe, it looks like the JWT version now.
Laterz
Aceman
