Ticking from rear axle
Old Nov 6, 2004 | 09:03 AM
ThreeFitty's Avatar
ThreeFitty
Default Ticking from rear axle
When I start to pull away my rear axle makes a ticking or pinging sound. Has anyone else had this problem?
Is it a warranty issue?
Thanks,
Jason
Old Nov 6, 2004 | 09:48 AM
maxipad96's Avatar
maxipad96
Mine does this too. It is covered under warranty, but I'm worried w/ my modified suspension. Its your rear axles. I took it in while I was still stock, they didn't have the parts so they had to order them. Since then, I have put eibachs on so we will see what they say.
Old Nov 6, 2004 | 10:28 AM
Zmego1985's Avatar
Zmego1985
Maxi your car looks great!!!!!!! Those rims look sick
Old Nov 6, 2004 | 03:06 PM
mchapman's Avatar
mchapman
Ive got like a loud metalic creaking as I pull away, is this the same thing?
Old Nov 6, 2004 | 03:41 PM
DIGItonium's Avatar
DIGItonium
Outer axel cover and wheel bearing... there's a TSB on it. It can be either or both sides in the rear wheels.
I had mine fixed last week just in time to get my new wheels on :-)
Old Nov 6, 2004 | 07:16 PM
Losing Grip II's Avatar
Losing Grip II
they replaced mine.
i have my car nearly on a max drop that the coilovers will allow and have sway bars. they said "looks nice" heres your fixed car"
they said that the suspension mods played no role in a drivetrain part. also said that this problem afects ALL 2003 and some early 2004 Zs. for me, they knew it was the problem and not the coils. still i dont think youll have a problem getting yours fixed.
john
Old Nov 6, 2004 | 09:11 PM
DrVolkl's Avatar
DrVolkl
Any problems if you don't get it fixed?
I don't trust dealers and don't want my wheels marked up.
Old Nov 7, 2004 | 03:42 PM
ThreeFitty's Avatar
ThreeFitty
Thanks for the help. I'm going to make an appointment this week at my dealer.
Old Nov 7, 2004 | 05:42 PM
Zmego1985's Avatar
Zmego1985
They were @ssholes at my dealer in MA they keep blaming the rear noise on my rear brakes. So im going to another dealer when i have the time. If i were you i would make a print out of the problem so they dont give you the run around.
Thanks Glen
Old Nov 8, 2004 | 04:50 AM
jester7500's Avatar
jester7500
ThreeFitty, I had the same problem. I took my car to my local dealer and they said my rear axles nuts weren't torqued to spec. It was covered under warranty. No sounds ever since.
Also, I don't know if you remember, but you took a look at the door ding on my driver's side rear fender, at the Hooter's meet a couple of weeks ago. I can send pics to refresh your memory. Please PM me with a quote to fix that ding. Thanks.
