O2 voltage at WOT? Need info
Old Nov 14, 2004 | 05:28 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Default O2 voltage at WOT? Need info
Ok, i'm trying to calibrate my Blitz R-VIT, and i want to set it up to read my O2 sensor voltage. However on the R-Vit, you have to calibrate it to read your O2 voltage at 100% WOT. (since every car is different). With the 350z, what should the voltage for the 02 read at 100%?
thanks
Old Nov 14, 2004 | 06:09 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I think the RVIT will tell you what it is running at WOT but for calibration purposes, use 0 volt as min an 1 volt at max, as I believe the Z uses narrow band sensors
Old Nov 14, 2004 | 08:14 PM
Tony@Performance
Ah, ok, thanks, that makes a bit more sense now. I'll try it.
thanks
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
FromGtoZ
Sep 20, 2015 03:41 PM
pdexta
Sep 14, 2015 11:27 AM
