DIY – How to polish your plenum (many pics)
Old Apr 9, 2010 | 10:16 AM
XERMAN2001's Avatar
XERMAN2001
Default DIY – How to polish your plenum (many pics)
I am not an expert or a pro, I am not telling you this is the way it is done or has to be done.
This is what I did and used to polish my plenum, I made this thread to help others.
If you know a better or faster way to do this by all means post how, we are all here just to help each other.
This job took me 25 hours over 4-5 days. If I had done it over 2 days and had a larger compressor I think I could have done it in much less time, around 16 hours possibly.
Before:
after:
before:
after:
before:
after:
Old Apr 9, 2010 | 10:17 AM
XERMAN2001's Avatar
XERMAN2001
I have seen a few zeds online here with a polished oem upper plenum and liked it so I decided to do mine. Some have done them themselves others have paid around $300 to get them done professionally.
Here is some of the equipment I needed to complete this project
-Safety glasses
-respirator
-ear protection
-gloves
I bought an extra plenum to polish that way my car would still be drivable. What it looked like when I stared, rough and dirty.
After 4 hours of using an air grinder with a 40 grit flap disk and a Rotary tool with a grinding stone. (should have took less time but even with 2 compressors I still had to wait for them to keep up)
-Air grinder
-40 grit flap disk
-Rotary tool with and assortment of grinding stones
On a small part of the plenum you can see I did a few more steps to see some shine, (I wanted some motivation lol)
Old Apr 9, 2010 | 10:19 AM
XERMAN2001's Avatar
XERMAN2001
After another 4 hours of using an air grinder with a 80 grit flap disk and a Rotary tool with a grinding stone and 80 grit flap wheel. (should have took less time but even with 2 compressors I still had to wait for them to keep up)
-Air grinder
-80 grit flap disk
-Rotary tool with and assortment of grinding stones, sanding wheels and flap wheels.
Old Apr 9, 2010 | 10:20 AM
XERMAN2001's Avatar
XERMAN2001
After another 6 hours of using an electric orbital sander with 80 grit sand paper, 120 grit sand paper and 220 grit sand paper. A Rotary tool with a 80 grit flap wheel and wire wheel. (should have took less time but even with 2 compressors I still had to wait for them to keep up)
-5 inch electric orbital sander
-80 grit sand paper
-120 grit sand paper
-220 grit sand paper
-Rotary tool with and assortment sanding wheels, flap wheels and wire wheels.
Old Apr 9, 2010 | 10:21 AM
XERMAN2001's Avatar
XERMAN2001
After another 3 hours of wet sanding by hand with 400 grit and 800 grit. A Rotary tool with a 80 grit flap wheel, wire wheel and sanding wheel.
-400 grit wet sand paper
-800 grit wet sand paper
XERMAN2001's Avatar
XERMAN2001
After another 2 hours of using an air die grinder with a felt/cloth wheel and a black compound/bar.
-Air grinder
-an assortment of felt/cloth wheels
-black compound/bar
Old Apr 9, 2010 | 10:22 AM
XERMAN2001's Avatar
XERMAN2001
After another 2 hours of using an air die grinder with a felt/cloth wheel and a White compound/bar.
After another 2 hours of using an air die grinder with a felt/cloth wheel and a Red compound/bar.
After another 2 hours of using an air die grinder with a felt/cloth wheel and Metal polish
--- another 6 Hours total---
-Air grinder
-White compound/bar
-Red compound/bar
-Metal polish
--HERE ARE THE PICS AFTER 25 HOURS OF WORK---
Old Apr 9, 2010 | 10:23 AM
XERMAN2001's Avatar
XERMAN2001
I hope that helps
Old Apr 9, 2010 | 11:43 AM
jv350z's Avatar
jv350z
Looks great. I wish I had the motivation to do all that work.
Old Apr 9, 2010 | 12:37 PM
beezee's Avatar
beezee
Nice job. Good idea you bought an extra. That way one can take it easy and see it as some fun job that can be done over a period of time.
Old Apr 9, 2010 | 01:16 PM
adamciya350's Avatar
adamciya350
Dam...that looks amazing
Old Apr 9, 2010 | 01:42 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Looks good ! I just did one for a buddy but I dont have air tools so i did it mostly by hand took me all winter!! I do more sanding with finer grits and less buffing (due to the lack of tools) I finish mine off with a big electric buffer they are a ton of work but the finished product makes it well worth it IMO.
Old Apr 9, 2010 | 01:45 PM
XERMAN2001's Avatar
XERMAN2001
hand sanding, oh god. This was enough work with air tool. By hand would have been a killer, no wonder why you spread it out over the winter. Its worth it n the end though
Old Apr 9, 2010 | 01:46 PM
XERMAN2001's Avatar
XERMAN2001
I also polished my strut bar. The bar is made of steel not aluminum so it can rust. The bar is not on the bar and was finished 4 weeks ago. It has been stored in the garage since then and shows no signs of rust. I am thinking/hoping that if I keep a protective coating of polish on the car it will not rust. If it does rust I will sand it again and clear coat it, or just reinstall my other oem bar.
-Air grinder
-1000 grit wet sand paper
-black compound/bar
-Red compound/bar
-Metal polish
i am not sure how long this took me, maybe 2-4 hours total.
before and after pics
Old Apr 9, 2010 | 01:47 PM
XERMAN2001's Avatar
XERMAN2001
spot saved for pics once installed
Old Apr 9, 2010 | 02:08 PM
Oh sugar that is very pretty.
Old Apr 9, 2010 | 02:14 PM
ImWeeZzel's Avatar
ImWeeZzel
my hat off to you for having lots of patience and providing such a well detailed thread with superior results
Old Apr 9, 2010 | 02:22 PM
albaugh81's Avatar
albaugh81
Good work man.
Old Apr 9, 2010 | 02:34 PM
cdoxp800's Avatar
cdoxp800
that's just impressive. Great job. It looks outstanding.
Old Apr 9, 2010 | 02:39 PM
duro78's Avatar
duro78
looks awesome just too much work
