5atf fluid help
Old Sep 16, 2014 | 04:24 PM
350Z86's Avatar
350Z86
Default 5atf fluid help
Ok I've read a lot on the 5at fluid change, one problem. I pulled the wrong hose off my radiator and let out an unknown amount of ATF out. If there is no dipstick how can I put the correct amount in? And I haven't searched to hard under the hood but where is the fill hole? Thanks
Old Sep 16, 2014 | 06:15 PM
jhc's Avatar
jhc
General & Tech Moderator
Pop your hood, go to passenger side, all the way back to the firewall next to battery. Find your top heater hose and go straight in front of that.
You didn't state your year but from what I've seen that should be close. OR,
Take it to JiffyLube and let them sort it. GL
Old Sep 16, 2014 | 06:23 PM
350Z86's Avatar
350Z86
Default 5at
Unfortunately I've just spent 10k on my motor and vortech and I won't be taking it to any jiffylube and just letting them sort it out. Lol thanks for the info though.
Old Sep 16, 2014 | 06:38 PM
remo1356's Avatar
remo1356
You are absolutely right on the location of the dipstick filler tube.
Old Sep 16, 2014 | 07:17 PM
jhc's Avatar
jhc
Exclamation
My friend, no insult intended. I saw your join date and nobody had offered help after 30 views, and I had no idea of your expertise. Just trying to help a brother out...
JiffyLube would be a perfectly acceptable solution for someone who can't find their dipstick after 6 years.
Good luck with your car!
Old Sep 16, 2014 | 07:26 PM
travlee's Avatar
travlee
Master
hehe........ i will play nice....
Old Sep 16, 2014 | 09:11 PM
jhc's Avatar
jhc
350Z86,
This may be of some use for you, idk-
http://lmgtfy.com/?q=nissan+350Z+atf+top-off
Good Luck with your car. And you are welcome.
Have a nice day,
Old Sep 17, 2014 | 03:50 AM
350Z86's Avatar
350Z86
I simply said I hadn't looked yet, I just built a whole vortech kit, full fuel system, and header back exhaust. I'm not retarded I just don't trust some little punk kid that makes $8 hr at jiffy lube on my car.
Old Sep 17, 2014 | 06:45 PM
spooncer_DK's Avatar
spooncer_DK
They actually do scam people on a regular basis. they will charge people for things they dont actually do. DIY or DIE
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Ace2347
Sep 22, 2015 03:12 AM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
