Engine Swaps For all your engine swap experiences, ideas, questions, & more..
No Power to Coil Packs
Old Jul 17, 2017 | 11:56 AM
Vora's Avatar
Vora
Default No Power to Coil Packs
As the title states, my coil packs aren't getting power. I just swapped my stock DE with 180k on it because I got rod knock for a DE out of an 04 G35 with 86k I picked up at a junk yard. The motor ran before I plucked it out.
After swapping it in, it will crank but won't fire up. I know there is fuel and just to check to see if I messed up the timing I pulled out the crank sensor to see if it would start in limp mode, to no avail.
What are some reasons I wouldn't be getting spark? Could the coil packs have gone bad in transport or something of the sort?
Old Jul 18, 2017 | 02:45 AM
bealljk's Avatar
bealljk
are all the coil packs not getting voltage? Please tell us that you quadruple checked that you plugged the harness in?
Old Jul 18, 2017 | 10:52 AM
Vora's Avatar
Vora
I have looked at every wiring harness diagram for the de and I'm not seeing anything I would have missed unless I missed a random ground. None of my coil packs are getting power.
could a cam position sensor have gone bad? I know my ignition relay is working and that was my first suspicion.
