Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Engine swap bugs
Old Nov 4, 2020 | 11:06 AM
Dyoun12's Avatar
Dyoun12
Default Engine swap bugs
Hi guys, I have an 04 350z that I put an 05 motor in. Right after the swap everthing was fine I drove the car for about 6 months, then I lost power to my fuel pump it ended up being the throttle body causing the problem so I replaced it. Now car stays in limp mode. I have done the pedal dance and replaced the pedal switch, and did the throttle relearn. Car is still stuck in limp mode with a low low idle if I don't keep the pedal to the floor then I can hit 2k rpms sometimes. I am lost.
the pic of the gages is with the pedal mashed slap to the floor. Also pease ignore the the airfilter set up my son broke the airbox just a quick fix till I can get it replaced.
Old Nov 5, 2020 | 12:32 AM
travlee's Avatar
travlee
Master
What are the codes?
Old Nov 5, 2020 | 12:34 AM
Dyoun12's Avatar
Dyoun12
P1122
ycdevil
Aug 17, 2023 09:57 AM
Jmiller21
Jul 18, 2018 04:03 PM
joeb1983
Nov 3, 2015 01:52 PM
WTFMike
Apr 19, 2015 04:50 PM
