Engine Swaps For all your engine swap experiences, ideas, questions, & more..
LS Swap clutch issue
Old Jun 3, 2024 | 04:25 AM
fisher4550's Avatar
fisher4550
Default LS Swap clutch issue
Hello this is the first time I've used this forum, I have swapped an ls into my 350z and am using the cd008 transmission. I used the ISR swap kit. I have the stock master and slave cylinder. I got the car running and have encountered what seems to be my clutch is over engaging. If I push the clutch half to three quarters of the way in the transmission goes into gear smoothly. If I push it in the whole way I am getting a chatter noise.
Has anyone encountered this issue.
Old Jun 3, 2024 | 11:41 AM
bmccann101's Avatar
bmccann101
id imagine youve intrucduced a bubble into the system when removing /installing the trans.
You want to use a vacuum bleeder for sure.
If i had used the stock trans in my own swap, id have replaced every part none the less, ie new master, slave and clutch line
Old Nov 18, 2024 | 08:35 AM
bmccann101's Avatar
bmccann101
re-replying to this .. id imagine you figured it out, but the other solution is to adjust your actual pedal and clevis/ master cylinder rod. You should have just a split second of lose play in the clevis end, or it will be pre engaging the pedal and will allow some clutch slippage.
Not sure what the stock pedal has for stoppers, but the rjm adjustable pedal kit has absolutely every adjustment you cna think of, including stoppers so it doesnt throw too far... if thats a no go, there are pedal mounted floor stoppers available , just give it a google search, they look like a big round pad disc and a threaded clamp for the back of the clutch pedal.
Old Nov 18, 2024 | 08:59 AM
fisher4550's Avatar
fisher4550
Thanks for all the info, but i figured it out, it wasnt the clutch over engaging.
Old Nov 19, 2024 | 06:13 AM
iideadeyeii's Avatar
iideadeyeii
Bolts loosening on pressure plate?
TOB noise?
What was it?
350DaysAyear
Jul 15, 2020 08:59 PM
Fl4t_Matt
Oct 19, 2019 09:09 PM
DaytonaBlueZ33
Nov 7, 2016 04:10 AM
Fun40zx
Aug 15, 2014 11:43 AM
08black350
Feb 27, 2011 05:25 AM
