Engine Intakes, Exhausts, Clutches, Turbos, etc...
FS: R&D Factory Valve cover Gasket Set
Old Feb 27, 2011 | 09:13 PM
BabyZiLLa's Avatar
BabyZiLLa
Price shipped to V1Y 9X5, Canada please.
Old Mar 3, 2011 | 10:25 PM
BlueDragonZ's Avatar
BlueDragonZ
Got it in the mail...thanks.
Old Mar 4, 2011 | 10:47 AM
R&DFactory's Avatar
R&DFactory
R&D Factory
good , thank you so much .
Old Mar 14, 2011 | 10:52 AM
R&DFactory's Avatar
R&DFactory
R&D Factory
still going .
Old Mar 22, 2011 | 09:38 PM
LaoSiFu's Avatar
LaoSiFu
Bump for a reliable vendor
Old Mar 24, 2011 | 01:07 PM
wesismyhero's Avatar
wesismyhero
I would like to order a set asap. I sent a email and a message no response
Old Mar 24, 2011 | 03:23 PM
murders's Avatar
murders
nice ill need a set sometime soon, anything other mod that can be done at the same time.
Old Mar 28, 2011 | 12:07 AM
R&DFactory's Avatar
R&DFactory
R&D Factory
what are you looking for ?
Team R&D/ed
Old Mar 28, 2011 | 12:09 AM
R&DFactory's Avatar
R&DFactory
R&D Factory
Here is a DIY Instructions on how to replace the OEM seals on your Nissan VQ engine.
1- THIS IS A SIMPLE HOLE SAW (SIZE 1 7/8 INCH) THAT YOU CAN BUY FROM MOST HARDWARE STORE. WE GOT OURS FROM ACE HARDWARE AND IT WAS $7-11
2- THIS IS HOW YOUR VALVE COVER LOOKS WHEN YOU TAKE IT OFF OF YOUR ENGINE
NOTE PICTURE SHOWN MOST LEFT SPARK PLUG HOLE DRILLED.
3- WARNING “PLEASE DO NOT REMOVE BAFFLE PLATE” WARNING
4- POSITION THE HOLE-SAW CONCENTRIC TO SPARKPLUG HOLE AND DRILL BAFFLE PLATE SLOWLY AND CAREFULLY.
5- YOU WILL ONLY NEED TO DRILL JUST ENOUGH TO DRILL THROUGH THE BAFFLE PLATE (WE CLEANED UP ALL THE DEBRIS TO SHOW YOU CLEAR PICTURE
DRILL ALL 6 POSITIONS AND CLEAN OFF DEBRIS WHEN DONE.
6- NOW YOU WILL BE ABLE TO POP OUT THE OLD O-RING GROMMET OUT OF THE VALVE COVER. PLEASE REPEAT 6 TIMES.
7- THIS IS WHAT IT WOULD LOOK LIKE WITH THE O-RING GROMMET OUT
8- USE BLACK RTV SILICONE ON TOP SIDE OF THE NEW O-RING GROMMET (WE USED CLEAR ON OUR DEMO PICTURE SO YOU CAN SEE BETTER)
9- PLACE THE NEW O-RING GASKET IN TO THE HOLE. NOW YOU ARE READY TO RE-INSTALL YOUR VALVE COVER GASKET TO YOUR ENGINE.
FOR MORE INFO PLEASE CALL R&D FACTORY
File Type: jpg
Old Apr 13, 2011 | 09:17 AM
R&DFactory's Avatar
R&DFactory
R&D Factory
to the top..
Old Apr 23, 2011 | 09:05 AM
R&DFactory's Avatar
R&DFactory
R&D Factory
up up up
Old Apr 27, 2011 | 07:06 PM
350Z400rwhp's Avatar
350Z400rwhp
Replacing my spark plugs and it looks like I have some o-rings leaking. Price of valve cover gaskets and o-rings shipped to 43016. Thanks!
Old Apr 28, 2011 | 05:43 AM
uzme8679's Avatar
uzme8679
price shipped to 22320 please
Old May 10, 2011 | 04:12 AM
FastWhiteZ's Avatar
FastWhiteZ
price for the ready to install kit shipped to 33626... thx
Old May 30, 2011 | 06:05 PM
Road Warrior's Avatar
Road Warrior
hello,
just replaced my plugs today and i had oil in my spark plug tubes but only on one side. i only have 27,000 miles...what a damn shame but my warranty has expired since mine is an 04'. can you guys help? would like to do this myself so hook me up with everything i will need for this repair - all seals related to this issue. i am thinking about doing both sides anyways...lmk.
thanks
Old Jun 2, 2011 | 05:45 PM
krazyrican76's Avatar
krazyrican76
I sent a PM with no response, how much shipped to 42223! Thanks...
Old Jun 5, 2011 | 02:33 PM
02234546's Avatar
02234546
so, $100 for 6 o-rings, OEM valve cover gaskets and OEM pcv valve and seal, right?
how about the valve cover?
and what does $150 include?
95618, price please.
Old Jul 5, 2011 | 11:38 AM
  #38
Itzcashew's Avatar
Itzcashew
So the kit you guys are selling are already pre fabricated? And its just pull and install?
Old Jul 19, 2011 | 08:43 AM
  #39
R&DFactory's Avatar
R&DFactory
R&D Factory
bump
Old Jul 21, 2011 | 11:06 PM
  #40
Andrei's Avatar
Andrei
I found out what part number the seals are. They are from a 2000 Maxima. http://www.courtesyparts.com/kb_search_result.php?keywords=[13276]+\%28a33b&cPath=1956_1957_1958_1962
Cant be charging people $60 just like that for a part they didn't make. It's ridiculous.
