FS: $170 stillen oil pan upgrade 350z z33 vq35de
Old Feb 10, 2011 | 08:53 PM
Alwayznvip's Avatar
Alwayznvip
Default $170 stillen oil pan upgrade 350z z33 vq35de
Brand New! I purchased and have no use for it because I also have the JWT Oil pan Spacer. Purchased off ebay for $190. Im looking to get $170 shipped. My loss your gain. Perfect for FI or track guys.
Increases Oil Capacity 1 Quart
VQ35DE Motors
Oil supply and temperature are critical when putting your VQ35DE engine through its paces. If your oil pickup becomes uncovered or your temperatures rise too high, catastrophic engine failure is just around the corner.
STILLEN's Oil Pan Upgrade ensures that your Z or G has an ample supply of oil. This upgrade allows for an additional quart of oil. The extra capacity will allow your VQ to run cooler and more efficiently. Our design expands into the available space below the engine, while keeping the pan within the protective confines of the chassis.
STILLEN's aluminum pan has cooling fins cast into it allowing heat to dissipate more effectively. An extension is provided for the oil pump pickup and new hardware is provided to attach everything to the engine. This simple, effective upgrade can be completed with normal hand tools. Complete instructions are provided.
Combine the STILLEN Oil Pan Upgrade with our STILLEN Oil Cooler for the 350Z and G35, and you now have a state of the art complete cooling solution for your oil system that keeps your VQ35DE's oil temp under control.
Attached Thumbnails 0 stillen oil pan upgrade 350z z33 vq35de-yhst-15342291949654_2143_7781098.jpg
Old Feb 11, 2011 | 06:22 AM
Alwayznvip's Avatar
Alwayznvip
SOLD!!!
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
_koubie_
Sep 20, 2015 06:34 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
