FS: VQ35DE part out and some aftermarket
Awhile ago I bought a complete motoer and then took it all apart. I pretty much have everything to put back a working motor. So I have everything for sale. Everything is OBO and also I have some after market parts
ARP Head studs (missing one nut, call ARP and get one cheap)100
NEW Cosworth Bearings Sold
NEW Thrust bearing Sold
Scotts performance Turbo cams (Similar to JWT satge 1) Sold
TEIN S Techs (USED) Sold
Upper and Lower Plenum 50 each lower plenum sold
Heads (won't seperate) 300
Short block (gutted) 400
Upper oil pan 70
Lower oil pan 25 sold
Crank pulley 30
Cranskhaft 100
Oilp Pump 50
Valve covers 80
Starter 40
Alternator 50
Headers 50
New OEM Headgaskets (has Lucas oil on them) 80
Stock Cams 50
Stock Pistons 50
Front and Rear Timing covers 50 each
Fuel Rails 60
Stock A Arms (stud on one has been dremeled off) 50
Center Console Cupholder 20
Speedometer (70k and taken apart, clear plastic lens is broken) 70
all plus shipping
Anyhing else just ask!!!!
Valve covers
ARP studs
Heads
Upper oil pan 70
Crank pulley 30
Cranskhaft 100
Oilp Pump 50
Valve covers 80
Starter 40
Alternator 50
Headers 50
Stock Cams 50
Stock Pistons 50
Fuel Rails 60
all plus shipping
Valve covers
ARP studs
Heads
Well I bought the motor seperated from the car and it had 80k on the miles. also I took the motor apart piece by piece and internally everything look good and nothing was abnormal. I did check to see if there was compression before taking it apart and it was just fine.
