Engine Intakes, Exhausts, Clutches, Turbos, etc...
We are Top Speed Pro 1
Old Dec 19, 2011 | 03:09 PM
TS PRO-1's Avatar
TS PRO-1
Vendor - Former Vendor
Default Top Speed PRO 1 exhausts - buy direct!
Hey all! I introduced myself last year when I first registered on here, but since we are now sponsors, I thought I'd re-introduce myself...as well as our company.
My name's George. I currently handle Marketing / Promotions / Sales for Top Speed (PRO-1) Auto Accessories in Addison, TX (Dallas area).
Me: I currently have an '09 370Z, a '92 NSX, & a '00 Prelude after having owned a string of fun sports cars in the past....including: '71, '72, & '73 240-Zs, two '77 280-Zs, '84 Corvette, '81 Ferrari 308 GTSi, two '84 Fieros, and a '71 Valkyrie (Ford GT-40 looking kit car on a tube-frame chassis w/ a mid-engined V8...Google that one if you're curious...)
Us: We make the infamous PRO-1 catback exhaust (as well as many other parts) for the 350Z/G35 & 370Z/G37...not to mention the GT-R and even the Altima coupe...that you've probably seen all over You Tube...as seen here on our Facebook page:
(https://www.facebook.com/permalink.p...23421264375004)
or directly at:
http://www.youtube.com/watch?v=UvaHf...ature=youtu.be
We also offer performance parts for many Import, European, and Domestic cars. In fact, we're the largest automotive performance parts manufacturer in TEXAS offering:
* 2,000+ parts
* 230+ different makes & models of cars we have parts for
* LOCAL (Addison) office warehouse of 25,000+ sq ft.
* $2 million of inventory in stock.
* You are buying direct from the source. We are not a middle-man who "drop-ships" FROM someone else...in fact, WE drop ship FOR others! This allows us to offer you pricing much lower than others.
Top Speed PRO 1 carries:
air induction kits and air filters, light weight aluminum radiators, lightweight pulleys, stainless steel turbo manifolds, upgraded radiator hose kits, performance stainless steel headers, high-flow test pipe cats, turbo down pipes, Y-pipes, stainless steel & titanium catback exhaust systems, rear section (axle-back) exhaust system, universal mufflers, polyurethane exhaust hangers, suspension coilover shock absorber kits, strut bar & suspension braces, sway bars, front control arm performance racing bushings, rear lower arm bars, adjustable camber arms, adjustable tension rods, rear toe control arms, rear track arms, short throw & adjustable shifters, custom steering wheels, racing seats, belt harnesses, shift *****, HID colored lights, LED lights, cam gears, engine torque dampers, universal oil catch tanks, inner fender liners & splash guards, selected front bumper covers, selected lower valances, selected lip kits, performance tires, batteries, turbo adapters, intercoolers, aluminum & stainless steel pipes, rubber & silicon hoses, clamps, front & rear lip kits, spoilers, and carbon fiber trim pieces!
Founded and in business since 1996, we provide the highest level of customer service and client satisfaction while offering only the highest quality products at competitive prices.
For pictures and sound & video clips of our products in action, search for Top Speed Pro-1 on YouTube or visit us on Facebook: http://www.facebook.com/profile.php?id=100001535057084
Top Speed Pro 1 Performance:
www.topspeedauto.com
Our eBay store:
http://stores.ebay.com/TOP-SPEED-PRO...ORMANCE?_rdc=1
Facebook us:
http://www.facebook.com/pages/Top-Sp...375004?sk=info
Call or e-mail me at 972-233-0888 / George@TopSpeedAuto.com for direct purchase pricing, as well as current availability and application questions.
Cheers,
George @ Top Speed
Old Dec 29, 2011 | 02:58 PM
TS PRO-1's Avatar
TS PRO-1
Many of you have heard of Top Speed, but may not be aware of everything we carry for Z's & G's...
370Z
Cat (High Flow Test Pipes) – Resonated or non-Resonated
Catback Exhaust - Stainless Steel
Cold Air Intake Pipe w/ Air Filter
Dual Catback Exhaust - Stainless Steel
Exhaust Y-Pipe
Intake Kit
Short Shifter
350Z
Catback Exhaust – Stainless Steel
Coilover Shock Absorbers
Engine Torque Damper
Exhaust Y-Pipe
Front Fender Brace
Front Spoiler
Front Sway Bar
Front Under Brace
Headers - Stainless Steel
Intake Kit
Performance Upper Radiator Hose Kit
Racing Intake
Rear Adjustable Camber Arms
Rear Adjustable Toe Arms
Rear Sway Bar
Short Shifter
300ZX
Brake Master Cylinder Stopper
Bypass Kit - HICAS
Drager Catback Exhaust - Stainless Steel
Dual Intake Kit
Front Adjustable Lower Tension Rods
Front Adjustable Upper Control Arms
Front Lower Tension Rods
Front Strut Bar
Headers – Stainless Steel
Intake Hose Kit
Rear Traction Rods – Race Version
Rear Toe Control Arms
Rear Upper Arms
Short Shifter – Adjustable
Subframe Bushing Collars – JDM Spec
Subframe Bushing Collars – Slotted
Subframe Bushing Collars – Solid Aluminum
Split Intake Kit
Turbo Blow Off Valve Flanges
Turbo Down Pipe - Stainless Steel
Upper Pillow Mounts – Front & Rear
Old Dec 29, 2011 | 03:12 PM
IfastR's Avatar
IfastR
Resonated Test pipes for a HR?? Any intakes??
Old Dec 29, 2011 | 05:45 PM
jdub1234's Avatar
jdub1234
I've bought the true duel exhaust from you guys. It sounds great. Just a little short with the fitment. About 3/4. Is that an common issue?
Old Dec 30, 2011 | 09:17 AM
TS PRO-1's Avatar
TS PRO-1
Test pipes for HR? Yes...but only non-resonated:
http://www.ebay.com/itm/Nissan-350Z-...ht_1749wt_1014
Intakes? Yes (again):
370Z
http://www.ebay.com/itm/Nissan-370Z-...f#ht_955wt_954
350Z
http://stores.ebay.com/TOP-SPEED-PRO...&_sid=24549228
Old Dec 30, 2011 | 09:20 AM
TS PRO-1's Avatar
TS PRO-1
The only time we've ever seen this issue is when the system is slightly mis-installed.
You have to loosely bolt everything together first (wiggling it to all fit) ...then tighten it all down. If you just bolt down each piece as you go, you can end up with this issue.
Are you still having a difficulty with it fitting or did you get it worked out?
LMK...
George
Old Jan 1, 2012 | 10:22 PM
ronn1's Avatar
ronn1
Default Sway bar Front
Is this a SOLID bar? Looks like Cusco bar...
Old Jan 2, 2012 | 09:34 AM
TS PRO-1's Avatar
TS PRO-1
Yes, this is ours...Top Speed...and it's a SOLID 35mm bar.
Specs are the same, bars are the same...but one has less of a price mark-up.
Old Jan 2, 2012 | 10:58 AM
ronn1's Avatar
ronn1
Damn nice price on ebay! Just ordered the Fronts...Unreal price for a Cusco knock off!! In fact I see from another member that the specs are indentical to Cusco and the INTRUCTION sheet looks the same..in JAPANESE..not Chinese..WTF??
TOP Speed:
Installed (not mine):
Actual Instructions included..note same stiffness specs as Cusco and in JAPANESE..not Chinese (I verified this on Google):
Actual Cusco:
Old Jan 6, 2012 | 01:39 PM
ztouring03's Avatar
ztouring03
i would love to read more reviews on your swaybars, how good are they with body roll?? i think my friend just ordered some so i would need to check them out when he installs them.
Old Jan 6, 2012 | 01:50 PM
*ICE*'s Avatar
*ICE*
been rocking your HKS replica exhuast since it was first introduced in 2009. Been solid ever since. Only problem now is my aftermarket titanium tips is rattle a bit during start up. No leaks or whatever else. Had it paired with Megan resonated TP and it sounds real mean..
Old Jan 9, 2012 | 12:27 PM
TS PRO-1's Avatar
TS PRO-1
I just posted this about them:
https://my350z.com/forum/suspension/...ml#post9551665
Old Jan 16, 2012 | 03:15 PM
TS PRO-1's Avatar
TS PRO-1
Just a link to our YouTube channel...with all our videos:
http://www.youtube.com/user/topspeedauto/videos
Old Jan 16, 2012 | 04:02 PM
Fluid1's Avatar
Fluid1
350Z
Front Adjustable Upper Camber Arms
Fender Liners (driver's and passenger's side front fenders please)
Front Strut Bar
Front Sway Bar
Front Under Brace
Oil Pan Upgrade
Radiator
Rear Sway Bar
Can I get pictures and prices on each of the above items for a 2003 350Z?
Old Jan 16, 2012 | 09:10 PM
TS PRO-1's Avatar
TS PRO-1
The EASIEST way to see what we currently have in stock, with the most up-to-date pricing (covering any sale pricing that periodically happens) is to search our eBay store here:
Just search my make or part and you'll get the best results of what's available...at the lowest pricing currently out there...
Old Jan 17, 2012 | 08:29 AM
mw9's Avatar
mw9
Nice bar, have to pick one up. Any deals for my350z members.
Old Jan 17, 2012 | 08:47 AM
TS PRO-1's Avatar
TS PRO-1
Yes on a deal through my350Z.com, but which bar though...strut or sway?
Old Jan 19, 2012 | 04:16 PM
Fluid1's Avatar
Fluid1
I think I was just told to "search" by a vendor/salesman. Thumbs down.
Don't lie about the products you carry- if you can't sell them to us, then you don't have them.
Old Jan 20, 2012 | 09:44 AM
TS PRO-1's Avatar
TS PRO-1
Wow...really?!?
I try to do something helpful and you want to trash on me???
Sure, I can get you all the pictures you want, with pricing, but since I sometimes have a delay in answering e-mails, I thought you might appreciate being provided an easy way to get all the answers you need anytime you want them...right away.
I do not appreciate being called a liar. We have the products and we can (and DO) sell them. We currently carry and have in stock what we offer...with the exception of when we sell out of an item and have to have our factory make another production run of a certain item. We are not set up to produce one-offs or single runs of a part. We are only able to keep our cost, and thus pricing, down by producing parts in large runs.
ALL items are stored at our location...no drop shipping done here. We are the direct source of the parts...in fact, we drop ship for others all the time.
Sheesh...try to help someone and I get ragged on...
Old Jan 20, 2012 | 11:43 AM
TS PRO-1's Avatar
TS PRO-1
Pictures and pricing:
Front Adjustable Upper Camber Arms - currently out of stock
http://www.topspeedauto.com/ProductC...idproduct=1821
Fender Liners - currently out of stock
Front Strut Bar - currently out of stock
Front Sway Bar
http://www.ebay.com/itm/Infiniti-G35...ht_1308wt_1014
Front Under Brace
http://www.ebay.com/itm/Nissan-350Z-...ht_1507wt_1014
Oil Pan Upgrade - currently out of stock
http://www.ebay.com/itm/Infiniti-G35...ht_1778wt_1014
Radiator - currently out of stock
Rear Sway Bar
http://www.ebay.com/itm/Nissan-350Z-...ht_1325wt_1014
